I went from FX8350 to i7 4820K. Believe me the difference is HUGE.
It's a shame amd didn't properly think about the pile driver as with 8 cores it should be a monster, if only the x79 6 core chips were cheaper
How huge? Did you do benchmarks before and after?
One of the best reviews of CPU bottlenecks I've seen is this one. Unfortunately it's a bit old now and only five not-particularly-new games and 3d mark.
At low/medium settings the Intel pulls away. At high/very high settings the i7 and 8350 are identical in some games, not in others. So unfortunately it's a bit of a gamble.
I put this to the test recently with a 32nm Westmere EP hex core CPU. In every test I did (three, there was no point continuing tbh) the AMD battered it. Now granted, the Intel has a bit of a derped frequency (2ghz) but from what you read on the net a £100 AMD chip should never ever touch any hex cored Intel no matter what the speed.
You're being silly, of course if you under clock an Intel hex far enough performance will drop off a cliff.
The CPU you have is 2-3 generations behind, nearly 5yrs old and was never even released to retail, it is clocked so slowly that even the i7 920 at the time would have out performed it.
Why did you even waste your money on such a poor CPU? just because it's an Intel hex? when people say that AMD CPU's can't touch Intel hex's they mean the ones released into the retail channel which weren't severely gimped and can overclock decently, not 5yr old engineering samples clocked at half speed.
