** GREAT SUB £100 GAMING CARDS FROM AMD!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
AMD are combatting NVIDIA's 750Ti with 250X and 265, both offer impressive performance for the money, check them out:-
Sapphire Radeon R7 250X 1024MB GDDR5 PCI-Express Graphics Card @ £74.99 inc VAT
The new SAPPHIRE R7 250X series is a new family of graphics cards targeting the enthusiast on a budget and mainstream users looking for increased graphics performance. It is based on the second family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN optimised graphics processing architecture.
Specification:-
- Core Clock Speed: 950MHz
- Shader Architecture: GCN
- Stream Processors: 640
- Frame Buffer / Memory: 1GB GDDR5
- Memory Width / Speed: 128 bit / 4500MHz
- Display Outputs: 1x DVI + 1x HDMI + 1x DisplayPort
- Power: 65W TDP
- Dimensions: 155(L)x104(W)x35(H) mm Size / 2-Slot Cooler
- 1x 6-Pin Required
- 2yr Warranty
Only £74.99 inc VAT.
ORDER NOW
Sapphire Radeon R7 250X Vapor-X 1024MB GDDR5 PCI-Express Graphics Card @ £89.99 inc VAT
The SAPPHIRE R7 250X Vapor-X OC Edition is the first card in this generation to use the SAPPHIRE exclusive implementation of Vapor chamber cooling technology. Previous products with Vapor-X have received world wide acclaim for delivering very efficient cooling that allows the card to run at higher speeds but with very low noise levels. Based on the latest GPU technology from AMD, the SAPPHIRE R7 250X Vapor-X OC Edition has 1GB of the latest DDR5 memory, and is factory overclocked with core clocks of 1100MHz and memory clocks of 1300MHz (5.2 GB/s effective) to deliver excellent performance.
Specification:-
- Core Clock Speed: 1100MHz
- Memory Width / Speed: 128 bit / 5200MHz
- Display Outputs: 2x DVI + 1x HDMI + 1x DisplayPort
- Power: 65W TDP
- Dimensions: 225(L)x110(W)x43(H) mm Size / 2-Slot Cooler
- 1x 6-Pin Required
- 2yr Warranty
Only £89.99 inc VAT.
ORDER NOW
Sapphire Radeon R7 265 Dual-X 2048MB GDDR5 PCI-Express Graphics Card @ £109.99 inc VAT
The SAPPHIRE R7 265 Dual-X has 2GB of the latest DDR5 memory clocked at 1400MHz (5.6GB/s effective) and core clocks of 900MHz (925MHz with dynamic boost) to deliver new levels of performance in its price segment. Performance is optimised with the latest version of AMD’s PowerTune technology.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 900MHz (925MHz Boost)
- Stream Processors: 1024
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin
- Power: 115W TDP
- Dimensions: 228(L)X109(W)X35(H) mm Size / 2-Slot Cooler
- 2yr Warranty
Only £109.99 inc VAT.
ORDER NOW
BARGAIN TIME ;)
MSI HD 7770 GHz Edition 1024MB GDDR5 PCI-Express Graphics Card @ £69.95 inc VAT
28 nm GCN (Graphic Core Next) Architecture
The new and 28nm GCN Architecture with more efficient process technology puts more transistors in less space, enabling a dramatic increase in Processing Power. Crank the settings, devastate your enemies and bear witness to absurdly high frame rates with AMD Radeon HD7000 series graphics card-DirectX 11 has never looked this good. Maximum setting and crazy performance shouldn’t be a compromise. The AMD Radeon HD7900 Series with the new 28 nm GCN Architecture assures that it’s not.
PCI Express 3.0
PCI-Express 3.0 delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU (GPU communication-up to 16GB/sec in each direction), maximizing the performance from your GPU when paired with the latest platforms.
AMD HD3D Technology
Enjoy the most immersive experience possible with full support for High Definition Stereoscopic 3D, a technique that presents 2D images (movies, games, photos) in a format that creates the illusion of three-dimensional depth when using compatible 3D displays / glasses / software.
GHz Edition
The gigahertz barrier has been broken. Armed with a stunning 1GHz GPU based on the revolutionary GCN Architecture, the AMD Radeon™ HD 7000 GHz Edition (Selected model) is quite simply engineered to annihilate.
Best Microsoft DirectX11 Support
The tessellation performance on AMD Radeon HD7000 is up to 2X faster than the previous generation, and DirectCompute performance is also faster to accelerate advanced post-processing, filtering, and anti-aliasing techniques. Direct X11 games has never looked this good.
Cutting-edge Quad HD display support (4K Support)
The display resolution on AMD Radeon HD7000 series is quadrupled to the resolution of 4KX2K( 4096X2160 ) from the outputs of DisplayPort 1.2 and HDMI.
Discrete Digital Multi-Point Audio
The AMD Redeon HD 7900 Series is the first GPU that can simultaneously output multiple and discrete audio streams via HDMI and DisplayPort Output.
Enhanced Multi-GPU Capabilities
Triple or quadruple gaming power with AMD CrossFireX Multi-GPU technology. Increase your gaming performance up to 2x with AMD CrossFire technology, 2.75x for TriFire configurations, or with QuadFire configurations. With AMD ZeroCore Power Technology, the graphics card in slave modes will be switched off in idle to maximize the power saving.
AMD Eyefinity 2.0
The next generation of AMD Eyefinity technology is here, featuring all-new support for stereo 3D, universal bezel compensation and brand new display configurations. Face it: the best just got better: The enhancements for AMD Radeon HD7000 series include: Stereo 3D-multi-display stereoscopic 3D support via DisplayPort 16K X 16K maximum display group resolution-output up to 268 megapixels per GPU.
- Core Clock: 1000MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4500MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
Was [£79.99] Inc. VAT
Only £69.95 inc VAT.
ORDER NOW
But these all seem to require additional power.. The 750ti are bus powered and i think this might give the 750ti a bit of an edge.
