Lets see if we can get some information on the best overclocking method for the FX8350 be it either using the FBS or the multiplier.
I currently have my CPU at 4.7Ghz @ 1.47v using the multiplier only FSB just left at the stock 200.
I have been told that using the FSB and leaving the multi @ 20 will help reduce my voltage therefore heat generation and also you get better performance.
Doing this effects the RAM, NB & HT
If using the FSB what's the best voltages you use (CPU - CPU/NB)
I assume I would also need to increase my CPU/NB voltage which is stock at 1.2v. I have heard 1.3v is safe for this but not completely sure.
I am hoping to hit 5Ghz completely stable its under water with a XSPC 480 & a 280 so I have sufficient cooling available
