Pulling files from Windows to Linux box with cwRsync
26 Aug 2012
North West
I have a set of machines, a mixture of Linux and Windows Boxes.
I hav set up rsync to pull from the Linux Machines to a Linux Server box.
I am trying to accomplish the same using cwRsync, to pull to the Linux box from the windows machines. I have downloaded the free version from https://www.itefix.no/i2/content/cwrsync-free-edition and also I have downloaded CopSSH. I have managed to install CopSSH fine and I am able to SSH between the Linux and Windows hosts no problem using keys rather than passwords.
However, for the life of me I can't get this cwRsync working, I've googled the matter to death, and your meant to unzip the directory, configure the environment settings in the batch file then install it. However, there is nothing to install it with! and the reason it isn't working is because it needs to install a windows service for it to run.
Any help would be much appreciated! Also an alternative, headless method to pull files from Windows to a Linux Box securely would be of use as well.
