I'd get that!!
Nice find![]()
This....awesome deal for a good card
Isn't that 280X just a 7950 re-marketed at the same point?
You can get used 7950's for about £140. Might be worth considering to save a lil money.
£20 extra (£220) would get you a brand new 280X (Re-branded 7970).
Really hope we get some new cards soon. Been the worst year ever for re-brands from both camps..
It is but for his Budget it's probably the best he can get. The next step up is 280x and gtx770 which are way over his budget. We all know the gtx760 is a bad option as it's to cut down.
It's a 280 (non-X), and yes, it's a 7950.![]()
What about a used 7950 to save some money? Or if can add another £20 on top the budget get a 280X (7970)?
If he can get a used 7950, then that could be an option.
I must admit, that due to the OP's resolution, I did wonder if a 270x would be worth throwing into the mix? It's so very, very close to a 7950 + boost, would save him more money & he would still end up with a brand new card :
http://www.anandtech.com/bench/product/1033?vs=1043
Looks like a decent jump up from his present card, too :
http://www.anandtech.com/bench/product/1039?vs=1043
