FIFA 14
Most of them are going for 500-550. Would have opened some packs using Fifa points but the Season pack discount does not work on the PS4. Other alternative is to buy some coins and open packs that way.
if you have 2 teams that your rotating and therefore not buying fitness cards you should be generating a healthy profit from playing seasons (even if your crap at the game due to large payouts for relegation and staying in divisions, etc).
the first thing i do in every fifa is build 2 quick sell teams use them until their contracts are up and then quick sell them and buy them again for quick sell price.
then i start buying managers until i have a healthy boost before going into more expensive players which require buying contracts for.
I need to go 433-2 with my BPL side but I just can't settle on who to have up front and who to have in midfield.
UP Benteke
Midfield:
Fernandinho (CM) Lucas Leiva (CDM) Yaya (CM)
That's quite defensive though...
If you wanted to go more attacking you could stick Yaya as CDM and get Ramires as your second CM.
I was thinking of trying UP Suarez up front, Hazard LW, Navas RW.
Midfield is the area of confusion for me.
Nasri, for me, doesn't with as a CM. Fernandihno is awesome though.
A balanced midfield work rate wise is H/M M/H H/H. You can make small variations like a M/M instead of H/M but your work rates are more important than the players I find personally.
Psycho Sonny,
lol ;)
1 game, won 5-3
they had 4 shots on goal and bond only saved 1 :P
will give him time and see how much better he gets i hope
that was playing starter cup (easy)
There is, but what? :p
Ligue 1, Serie A, Liga BBVA, Brazil sides; French sides, Spanish sides. Hybrid sides are where the game really comes to life IMO.
They also have interchangeable options. The point of ultimate team is that you can largely do anything. Also even within Ultimate Team there's many options. I think within BPL you've only tried what, maximum of 15-20 players?
