- 11 Dec 2005
- Cheshire
The highlights of this week's deals are as following:
This week we are offering a the epic Roccat Kave Gaming Headset for only £54.95 inc VAT! Delivering ultra-realistic 3D sound for a truly immersive gaming experience.
Enjoy true true HD 1080p gaming with the Iiyama Prolite XU2390 23" Slim Monitor! With an super slim bezel, the Prolite is perfect for multi monitor setups, where thin bezels are most desirable.
Looking for an efficient CPU cooler? Look no further than the Raijintek Rhea Heatpipe CPU Cooler. Packing a PWM controlled 92mm fan and a 3 piece heat pipe system for maximum thermal control. Yours for only £12.95 inc VAT.
Want more? Our whole selection of deals HERE.
Roccat Kave 5.1 Surround Sound Analog Gaming Headset @ £54.95 inc VAT
Only £54.95 inc VAT.
ORDER NOW
iiyama Prolite XU2390 23" Widescreen Slim Bezel LED Multimedia Monitor - Black @ £125.99 inc VAT
ProLite XU2390HS is a 23” LED backlit LCD Screen featuring IPS Panel technology which is considered to be the best all round panel type. It offers accurate and consistent colour reproduction with wide viewing angles (178°/178°) and fast response time (5 ms black-to-black). XU2390HS is full HD, has a >5mln:1 Advanced Contrast Ratio and 250 cd/m² brightness offering the user a clear and vivid image. The ProLite XU2390HS will provide excellent performance for photographic design, web design, standard office use and in multi-monitor environment. Very suitable for multi-monitor Digtal Signage and office applications.
The IPS panel technology guarantees consistent colour reproduction with wide viewing angles and high contrast and therefore it is especially recommended for graphics design and other applications which require colours to be displayed accurately. The response time of the panel allows for smooth playback while watching films and playing games, making the IPS the best all-round technology suitable for both business and home use.
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Specification:-
- Diagonal: 23"
- Panel: IPS LED
- Display area: h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time: 5 ms
- Contrast: 1000:1 typical
- Contrast: 5000000:1 ACR
- Brightness: 250cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 16.7 million
- Pixel pitch h x v: 0.265 x 0.265 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 56 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16:9
- Connectivity: DVI-D, HDMI, VGA, HDCP
- Dimensions: w x h x d 532.5 x 387.5 x 180 mm
- Speakers: 2 x 2W Stereo
- Tilt Angle: 20 degrees up / 4 degrees down
- VESA Mount: Yes 100 x 100mm
- Weight: 4.0kg
- Warranty: 3yr
Only £125.99 inc VAT.
ORDER NOW
Raijintek Rhea Heatpipe CPU Cooler - PWM - 92mm @ £12.95 inc VAT
RHEA, Raijintek's compact size performance cooler, is a cooler with C.D.C. (CPU Direct Contact)and designed by German Engineers. With 3pcs of F6 mm heat-pipes and light material fins, plus a powerful but quiet 92mm fan, Rhea supports nowadays most popular Intel LGA 1150/ 1155/1156 Socket CPU’s and is easy to install in seconds for users.
Non-Copper base design (C.D.C. - CPU Direct Contact)
92mm highly efficient PWM fan
3pcs high performance U type heat-pipe
Light weight and 118 mm height for most desktop system
Compatible with Intel modern sockets at market
Point of view of budget price
Easy installation and user friendly
Specifications:-
- Dimensions: 93 x 118 x 59 mm (W x H x D)
- Material: aluminum (fins, bottom), copper (heatpipes)
- Weight: 250 g (without fan)
- Heatpipes: 3x Ø 6 mm
- Fan: 92 mm (max. 27.9 dB (A), 800-2200 U / min, 57 m³ / h, 1.67 mmH2O)
- Starting voltage: 7 V
- Connector: 4-pin PWM
- Life expectancy: 40,000 hours
- Compatibility: Socket 1150, 1155, 1156
Only £12.95 inc VAT.
ORDER NOW
ORDER NOW
Specification:-
- Diagonal: 23"
- Panel: IPS LED
- Weight: 4.0kg
- Warranty: 3yr
ORDER NOW
Specifications:-
ORDER NOW
