These new boards from Razer dont have cherry switches but instead come with switches optimised by Razer to be more focussed for gaming.
The switches are made by a company called Kailh for Razer.
Altered activation points and weighting make them ideal for gaming.
Whats more is that the Razer switches dont pay licensing costs to cherry meaning the switches are cheaper to produce.
This is fantastic news for you lot because it means you can get a Razer Mechanical Keyboard for a lot less money than last years 2013 model which had cherry switches.
the new Razer switches made by Kailh have the same sort of design as a cherry switch meaning they are compatible with aftermarket keycaps and keyboard mods.
Razer Blackwidow 2014 - Expert Mechanical USB Keyboard @ £89.99 inc VAT
Designed specifically for gaming, the all-new Razer Mechanical Switches actuate at an optimal distance, giving you speed and responsiveness like never before. No matter how intense your gaming marathons get, each Razer Mechanical Switch is engineered to withstand up to 60 million keystrokes, so you’ll enjoy the Razer advantage for longer. Never miss a single key, or ten for that matter. With built-in anti-ghosting technology, the Razer BlackWidow lets you perfectly execute up to ten commands at the same time, every time.
Key Features:
- Razer™ Mechanical Switches with 50g actuation force
- 60 million keystroke life span
- 10 key roll-over anti-ghosting
- Fully programmable keys with on-the-fly macro recording
- 5 additional dedicated macro keys
- Gaming mode option
- Audio-out/mic-in jacks
- USB pass-through
- 1000Hz Ultrapolling
- Razer Synapse 2.0 enabled
- Braided fiber cable
Specifications:
- Macro Keys: 5
- Key Switch Type: Razer Mechanical 50g Actuation Force Switch
- Anti-ghosting: Up to 10 keys
- Key Strokes: 60 Million
- Interface: USB
- Cable Type: Braided 2.0 meter
Only £89.99 inc VAT.
ORDER NOW
Razer Blackwidow Tournament Edition 2014 Essential Mechanical USB Keyboard @ £69.95 inc VAT
Designed specifically for gaming, the all-new Razer Mechanical Switches actuate at an optimal distance, giving you speed and responsiveness like never before. No matter how intense your gaming marathons get, each Razer Mechanical Switch is engineered to withstand up to 60 million keystrokes, so you'll enjoy the Razer advantage for longer. Together with detachable USB cable, the Razer BlackWidow Tournament Edition gives you all the essential keys in a sleek, compact form, perfectly suited for your gaming needs on-the-go.
Key Features:
- Compact layout
- Detachable braided fiber USB cable with cable strap
Specifications:-
- Interface: USB
- Cable Type: Detachable braided fiber USB cable with cable strap
- Case Colour: Black
- Product Width: 154mm
- Product Length: 366mm
- Product Height: 30mm
- Product Weight: 0.95Kg
Package Contents:-
- Keyboard
- Quick start guide
- Razer Sticker
Confirmation of Razer (Razer Certificate)
Only £69.95 inc VAT.
ORDER NOW
Razer Blackwidow Ultimate Stealth 2014 Elite Mechanical USB Keyboard @ £124.99 inc VAT
Description:
Designed specifically for gaming, the all-new Razer Mechanical Switches actuate at an optimal distance, giving you speed and responsiveness like never before. No matter how intense your gaming marathons get, each Razer Mechanical Switch is engineered to withstand up to 60 million keystrokes, so you’ll enjoy the Razer advantage for longer. Whether you’re gaming under low-light, or no light, individually backlit keys ensure you never misclick – after all, it could very well be the difference between victory and death.
Key Features:
- Razer™ Mechanical Switches with 45g actuation force
- Individually backlit keys
- USB pass-through
Specifications:
- Macro Keys: 5
- Key Switch Type: Razer Mechanical 45g Actuation Force Switch
- Interface: USB
- Backlighting: Individually backlit
- Audio Ports: 2 x 3.5mm Jacks ( Headphones and Microphone)
- Product Width: 171mm
- Product Length: 475mm
- Product Height: 20mm
- Product Weight: 1.50Kg
Package Contents:
- Keyboard
- Quick start guide
- Razer Sticker
- Confirmation of Razer (Razer Certificate)
Only £124.99 inc VAT.
ORDER NOW
Razer Blackwidow Ultimate 2014 Elite Mechanical USB Keyboard @ £124.99 inc VAT
Key Features:
- USB pass-through
- Braided fibre cable.
Specifications:
- Macro Keys: 5
- Interface: USB
Package Contents:
- Keyboard
- Quick start guide
- Razer Sticker
ORDER NOW
Key Features:
- USB pass-through
Specifications:
- Macro Keys: 5
- Interface: USB
ORDER NOW
Key Features:
- Compact layout
Specifications:-
- Interface: USB
Package Contents:-
- Keyboard
- Quick start guide
- Razer Sticker
ORDER NOW
Description:
Key Features:
- USB pass-through
Specifications:
- Macro Keys: 5
- Interface: USB
Package Contents:
- Keyboard
- Quick start guide
- Razer Sticker
ORDER NOW
Key Features:
- USB pass-through
Specifications:
- Macro Keys: 5
- Interface: USB
Package Contents:
- Keyboard
- Quick start guide
- Razer Sticker
ORDER NOW
