It will all depend on what you are doing for them though won't it it will be on a sliding scale depending on your role for the area you will be locally employed eg what grade will you be expected to function at, whether you are required to do IVs, whether you are required to do an extended role eg phlebotomy, whether you will be 'in charge' etc. That's why they can't say I would wager although they should be able to give you the payment for each banding level and if they can't they aren't worth bothering with. If you are expected to be in charge then don't settle for less than band 6, if you are expected to do IVs don't settle for less than band 6, if you are performing advanced roles expect band 7 tbh. Don't forget the rates will vary for each health trust and even within the trusts eg haemo will get more etc.
