Titanfall (Respawn Entertainment's new IP)
[FnG]magnolia;25994737 said:
I probably should have checked to see what the Data Centre set up was for Australsia before buying this game.
Closest centre - US West Coast with a ping of around 150ms :/
Ouch. You'd think they'd have some Asian data centres up what with Korea and Japan being big on games. :(
Best thing about the game is being able to play competitively with a 360 controller. So much more relaxing and inviting for a quick play than BF4.
Anybody remember the Vsync issue with a keyboard and mouse on Dead Space? IIRC using a 360 pad enabled you to play the game with Vsync enabled and without any lag. Anybody tried this on Titanfall?
Woah, massive amount of graphical corruption with my 7990. Time to fiddle with some drivers.
Right I had this problem today when I upgraded to the newest beta drivers. A clean driver wipe and install did not help. If anything it made it worse as I couldn't install the newest drivers without bluescreening. I has to system restore back and by checking now I am running drivers 13.25.18-.... and Cat version 13.11.
I really think the newest drivers are really bad with Titanfall. The corruption was crazy. Just popups and really large text all over the screen.
Using xfire 7950s
The gfx corruption is because you are using crossfire, when i disabled crossfire it runs perfectly. Not sure if you can disable it with a 7990 though :(
Does anyone else find they always end up in a rubbish team?. I have played 28 games and only won 6 :o
I'm not the best player in the world but usually end up in the top 3 and have been mvp quite a few times and I'm slowly getting used to kb & mouse as I mainly play my games on console.
Haha I literally just enabled xfire and went in and have just come out the to turn it off and you post.
Great. So I need to disable xfire for the moment to run this game. Awesome... Hurry up AMD.
So what kind of stats are people getting - Win/loss and K/D?
I normally don't bother comparing / willy waving, but I don't know what's considered normal. I normally aim for 2.0 in games like BF, that's kind of a target I set myself, but Titanfall is obviously different to the standard FPS games in the way K/D is calculated because of the grunts.
Arc cannon is garbage. The semi auto primary pilot weapon is also poor up close and even at range too compared to the other weapons. I can't see any use for it over the carbine or SMG. Spitfire is crazy powerful but has big recoil. Satchel charges are good fun and cause a big boom. Also using the Mag grenades now instead of the Archer heavy missile.
Tried to play campaign but ran out of players at the last mission. Will pick it up again on Friday I guess. Going to be a bit of a Turkey shoot for a few days!
Wonder how big the day 1 patch will be, hopefully nothing big, I've been waiting all week to play this. Probably should've just used a proxy to play earlier but only one more day to go. :p
