KFA2 Geforce GTX 780Ti HOF 3072MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
The KFA2 GTX 780Ti HOF is produced with a white PCB, two 8 pin PCI-E power connectors for a maximum TDP, a Hyper boost button and Cooled with custom hybrid cooling solution - a combination of a Vapor chamber and heat pipes. Upto 20% performance gain Vs the standard GTX 780Ti and up to 10c cooler.
Specification:-
- GeForce GTX 780Ti HOF
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1020MHz
- Core Boost Clock: 1085MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £499.99 inc VAT.
ORDER NOW
_____
KFA2 GeForce GTX 750Ti OC "Low Profile" 2048MB GDDR5 PCI-Express Graphics Card (75IGH8HX9KXZ) @ £99.95 inc VAT
GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
Specification:-
- Core Clock: 1072MHz (Maxwell)
- Core Boost Clock: 1150MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5400MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x Dual-Link DVI-I, 1x HDMI & 1x Analogue
- HDCP Capable
- DirectX 11.2 Support
- OpenGL 4.4 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Extremely Lower power consumption (Maximum consumption 60 watts at stock speed)
- NO external PCI-E Connectors required
- Warranty: 2 Years
Only £99.95 inc VAT.
ORDER NOW
Specification:-
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
_____
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
