What could burning near wheel mean after a drive?
31 Dec 2003
Stoke on Trent
Hi all,
Got out of my EP3 this morning and my rear driver side wheel was SMOKING, and smelt really badly burning.
What do you think it could be ? A stuck caliper? I am not technical with cars in the slightest but wondering if it's drivable home and to a garage tomorrow?
Thanks for any tips!
At lunch, go out and take your wheel off, I'd hope you'd have a jack and brace in the boot.
Will be stuck caliper/handbrake and it'll ruin your wheel bearings, brake pads and discs.
Yep, seized brakes by the sound of it.
How long is your drive home? Given that it was smoking from your drive in this morning then I wouldn't drive on it again - if you have sudden pad failure then you could be in a world of pain.
First things the previous owner of my car (Honda) said was, "never leave it parked up with the handbrake on"
They're renowned for sticking calipers.
Ask a garage to free it up and clean it. More often than not it will be repairable. If there's not too much damage to the disc / pad, it could be a cheap fix..
Potentially, though, you're looking at..
Replacement caliper, new discs for both sides, new pads both sides.
edit, just seen you're Stoke. I'd go to somewhere like Tegiwa, they'll have tons of spare calipers and know the car inside out.
Last sentence sums it up well, you with RAC or AA surely they could check if you don't have tools ready to take the wheel off. Having said that, if you took the wheel off what could you do by the road side if the brake is seized. Only sensible suggest is to call RAC or AA really and if it's unfixable then at least they can tow to garage.
My DC5 had the same rear calipers and they were pants, i always parked up without the handbrake as the pads used to seize onto the disc and then because of that the whole caliper on the off side just stopped working...
Don't drive it if it was hot enough to smoke that'll be doing quite a few components no good at all.
Reason why people get sticking caliper slider pins is because they never lube up their sliding pins, keep them lubed with some silicone grease or red rubber grease and it won't be a problem, it isn't an inherent fault but a maintenance issue.
Sounds a sensible thing to ask the RAC etc (I'm with AutoAid) but the first question they ask is "Is the car drivable" and if the answer to that is "yes" they tend to refuse to come out, so I'm stuck with little choice other than to drive it.
In response to acemastr, I don't carry my trolley jack in the car with me just the stock scissor one and I dont trust that thing so I'm not going to jack it up, besides, what would I do once it's jacked anyway? I know nothing about cars.
I'm a 13 mile drive from home.
Just lie on the phone, tell them one wheel isn't moving at all, "I think the one of the brakes is jammed on"
Believe me, mine have.been greased up to within inches of their lives whenever I've changed pads, and they still stick.
Or Moly sulphide as deemed by the high pressure and temperature environment.....
If the seals were better design and the spring release better for the handbrake you'd get the pads of the disk easier.
You cant really lube the piston either if its corroded as the job of the seal is to keep water out.... again a poor design as the stroke of the piston through pad life tends to lift the seal the piston away from the caliper body.
