- 20 Feb 2009
- Ashton-Under-Lyne
Basically, OCUK have the tubing I want in 16/10, but not 16/11 (which is what my current tubing is) am I likely to be able to use the smaller ID tubing with the fittings? They're the EK PSC compression fittings (which are actually listed in my order history as 16/12)
My guess is IF I can get the tubing onto the fittings, it'll be fine, but the main issue is if it's actually likely to be possible, has anyone tried it? From memory, the current tubing was quite a tight fit as it was, and required a decent amount of heating to allow them to go on.
