I'm a little nervous about wall mounting my plasma TV which weighs in at 36.4KG. Though as needs dictate, can somebody recommend a wall mounting mechanism that might assuage my apprehensions.
Regards
Many thanks for the recommendation. Not cheap is an understatement.
Many thanks for the recommendation. Not cheap is an understatement.$625 is over £350! Do you know of anything nearer to the £50 range.
Cheers. I will only need tilt functions as it's going up fairly high on a brick, chimney breast wall.
Cheers, I've seen that one. What model is your TV and how much does it weigh?That's exactly what I used my bracket for:
http://www.amazon.co.uk/gp/product/B003U46SWC/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I installed that into a brick chimney breast - above the old fireplace. It comes with 6 large wall bolts. You don't need to pay any more. It's been up since August and is extremely sturdy. The truth is that 36kg is pretty standard tbh.
One annoying thing about it is that you have to reach behind the TV and unscrew fastening screws by hand - whereas more expensive ones have a spring mounted mechanism but how often are you going to remove the TV from the wall once all is complete?
Cheers. I went through almost all the 1500 reviews looking specifically for the people who stated they had TV's over 35KG and found too many disconcerting reviews to be 100% sure it would cope more than adequately. It prompted me to find one a little more expensive in the same range that was built with sturdier materials and they have one for just over £20 which I may get. The other I'm considering is made by Cheetah and costs £29 but also comes with a free 3m good quality HDMI cable.Panasonic P42GT30 - only around 20KG but it's the reviews of the product i'd draw your attention to. It's rated to 75KG so I think we can agree it wil hold half that.
Seriously 36KG is a non issue.
Maybe, though I'd rather err on the side of caution. Some of the guys with 35KG TV noticed a bend in the attachment and it just seemed sensible not to ignore this. Especially when for a few pounds more I can get something made of stronger material and also the kind of mechanism I prefer. http://www.amazon.co.uk/gp/product/B000WL6YY8/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A20ASF6PRMN86Good stuff.
From my perspective I think you're over thinking it but I'm glad you're not contemplating paying much more.
