Hi there
As always EVGA like to go one better than everyone else with their warranty and service, 10yr warranty, NUFF SAID!
Three deals for you guys:-
EVGA SuperNova G2 1000W '80 Plus Gold' Modular Power Supply @ £139.99 inc VAT
The EVGA SuperNOVA 1000 G2 has arrived! This power supply is 80 Plus Gold Rated, offers 1000W of continuous power, exceptional efficiency and is fully modular. Not to mention, a first class 10 Year EVGA Warranty. Designed with enthusiast needs in mind the EVGA SuperNOVA 1000 G2 power supply is the best choice to power this and next generation enthusiast computers. Take your system to the next level and power up with the EVGA SuperNOVA 1000 G2!
NOTE: For power supplies purchased in Europe, a European style power cable will be provided.
Features:-
- Unbeatable 10 Year Warranty and unparalleled EVGA Customer Support
- 80 PLUS Gold certified, with up to 90% efficiency under typical loads
- Highest quality Japanese brand capacitors ensure long-term reliability
- Fully Modular to reduce clutter and improve airflow
- NVIDIA SLI Certified
- Sanyo Denki Ball Bearing fan for exceptional reliability and quiet operation
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP (Over Current Protection), OPP (Over Power Protection), SCP (Short Circuit Protection), and OTP (Over Temperature Protection)
Was [£149.99] Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply @ £109.99 inc VAT
Unleash the next generation in power with the EVGA SuperNOVA 850 G2 Power Supply. Based on the award winning G2 series Power Supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The new ECO Thermal Control Fan System offers fan modes to provide zero fan noise during low load operations. Backed by a 10 year warranty and Japanese capacitor design, the EVGA SuperNOVA 850 G2 is not only the right choice for your system today, it is also the best choice for your system tomorrow.
Features:-
- NVIDIA SLI Ready
- Double Ball Bearing fan for exceptional reliability and quiet operation
- Heavy-duty protections, including OVP (Over Voltage Protection), UVP (Under Voltage Protection), OCP - (Over Current Protection), OPP (Over Power Protection), and SCP (Short Circuit Protection)
Specification:-
- ATX Cable 1x 600mm (m)
- EPS Cable 2x 700mm (m)
- PCIE Cable 2x 700mm, 850mm (m) 2x 700mm (m)
- SATA Cable 2x 550mm, 650mm, 750mm (m) 1x 550mm, 650mm, 750mm, 850mm (m)
- Four-Pin Peripheral Cable 1x 550mm, 650mm, 750mm, 850mm (m)
- Floppy Adapter 1x 100mm
- AC Power 1x 1500mm (m)
- CONNECTOR QUANTITY
- 24 Pin ATX 1x
- EPS (CPU) 2x 8pin (4+4)
- PCIE 4x 8pin (6+2), 2x 6pin
- SATA 10x
- Four-Pin Peripheral 4x
- Floppy 1x
- 12v: 70.8A
- Size: 85mm (H) x 150mm (W) x 180mm (L)
- Approvals: TUV, CB, CE, FCC, RCM, cTUVus, BSMI, WEEE, RoHS
- Warranty: 10yr
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply @ £89.99 inc VAT
Unleash the next generation in power with the EVGA SuperNOVA 750 G2 Power Supply. Based on the award winning G2 series Power Supplies from EVGA, this PSU features 80 PLUS Gold rated efficiency, and clean, continuous power to every component. This provides improved efficiency for longer operation, less power consumption, reduced energy costs and minimal heat dissipation. The new ECO Thermal Control Fan System offers fan modes to provide zero fan noise during low load operations. Backed by a 10 year warranty and Japanese capacitor design, the EVGA SuperNOVA 750 G2 is not only the right choice for your system today, it is also the best choice for your system tomorrow.
Features:-
- NVIDIA SLI Ready
Specification:-
- PCIE Cable 4x 700mm (m)
- SATA Cable 3x 550mm, 650mm, 750mm (m)
- Four-Pin Peripheral Cable 1x 550mm, 650mm, 750mm (m)
- 24 Pin ATX 1x
- SATA 9x
- Floppy 1x
- INPUT
- Input Voltage 100 - 240 VAC
- AC Input 10A
- Input Frequency Range 50 - 60 Hz
- Efficiency Gold Rated - 90% Typical
- 12v - 62.4A
- Dimensions: 85mm (H) x 150mm (W) x 180mm (L)
- Approvals TUV, CB, CE, FCC, RCM, cTUVus, BSMI, WEEE, RoHS
- 10yr Warranty
Was [£99.95] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Features:-
ORDER NOW
Features:-
- NVIDIA SLI Ready
Specification:-
- 24 Pin ATX 1x
- SATA 10x
- Floppy 1x
- 12v: 70.8A
- Warranty: 10yr
ORDER NOW
Features:-
- NVIDIA SLI Ready
Specification:-
- 24 Pin ATX 1x
- SATA 9x
- Floppy 1x
- INPUT
- AC Input 10A
- 12v - 62.4A
- 10yr Warranty
ORDER NOW
with the latest 750G2 and 850G2 the cables are all black
