Titanfall (Respawn Entertainment's new IP)
This can't be right. Never see my download speed this fast before. 1gb downloaded in a few minutes.
Hmmm. Maybe my line has been upgraded.
it unpacks as it downloads, so it will be an inflated rate, your actually only downloading around 20-21gb :)
Question, is this fun to actually play or is it just a constant cycle of spawn > die > spawn > die.
Is it as annoying as playing a COD game or fun like a BF game?
It depends on your play style and thought process really. I find both CoD and BF can be annoying, however with TF I feel that the times I get annoyed it's more to do with a players play-style than the game itself causing issues.
The only uncontrollable annoyance I've found is autotitan's aimbotting from half way across the map, but then I can just get in my own titan and take out some frustration :p
I've only had one instance in over 8 hours play where a particular player has been extremely annoying; the killcam suggested that I was lagging behind so from my perspective it was as though the second he appeared around a corner I was dead.
On the whole, I find BF has more instances of annoyance than TF.
Regret buying it now, all to repetitive.
it is extremely repetitive, there's a heavy reliance on playing with and against a good team, otherwise it's just a steamrolling either way, which is never fun but seems incredibly tedious in TF compared to BF where there's just more going on in the map. That being said, when there's two good teams it doesn't feel repetitive at all and more akin to a close match of TDM or CTF in the days of UT.
Well, I find both CoD and BF annoying as hell and am enjoying Titanfall a great deal. Make of that what you will :D
Well I am set waiting on my son finishing karate all I want to do is rip a pilot a new a hole.
If you combine a dash card with a titan punch do you get a more powerful punch?
Game has decided to stop working for me, can't even get passed the initial logo screens.
This all began after I got a crash midgame for titanfall.exe relating to materialsystem_dx11.dll
That is the error I was getting, check back a few pages for an earlier post of mine, some of the suggestions in the links helped some sort the issues.
Edit. Just saw you were fixed :)
Has anyone solved the HUD issues when running with nividia surround triple displays?
I'm sure I read recently that this is a known issue and the devs are planning to fix it in an upcoming patch. Fingers crossed proper SLI support will also be included, why these features weren't implemented for launch I don't know!
Anyone playing this with a GTX 460, if so does it play OK?
I am in 2 minds if I should buy this or not, my reactions are a lot slower than they were when I played in a few clans years ago so would get dicked regularly, but I did enjoy the XBox One beta but would prefer it on the PC for keyboard and mouse.
I got home from work last night and decided to play Titanfall for a few hours (around 3.5 in total). I got to level 17 in that time, although I don't know if that is a good or bad performance?? :D
Level 17 in 1 hour 37 minutes. Is this a race? :P
Enjoying it but I prefer the pilot vs pilot battles and often just let my titan do it's own thing while I run around killing people.
Just got past the training stage. Tried connecting to a game, gets past the lobby countdown, loads the map, then loses connection to the server. Did this twice in a row now.
Solution?
