windows 8.1 32 to 64bit
14 Dec 2005
am i right in thinking that 4GB is the max ram a 32bit version of windows can use? (says 3.12GB usable in my system info)
I did the upgrade to win8 from XP for £25 a while ago - would it be possible to download the 64 bit version now or will I have to buy a new copy?
Don't quote me on this, but your key will work if you had a 64bit disc.
I done exactly the same.
Follow this......
Jimbo,
Download the x64 ISO for your version of Windows 8.1 - if you're not a MSDN/Technet member it can be a bit of a faff to find a trustworthy source, but check out "The Windows 8.1 (& related) Repository" thread on the My Digital Life forum.
Install it using the 8.1 Pro placeholder key XHQ8N-C3MCJ-RQXB6-WCHYG-C9WKB
When you're done and you're satisfied that everything's up and running OK, change the product key to the one you purchased.
Activate and enjoy.
This is the thread.....
http://forums.overclockers.co.uk/showthread.php?t=18571245&highlight=username_Jimbo
