It doesn't, OP says he's installed win7 on the mechanical HDD.
OP, did you try installing win8 on the mechanical HDD?
So Windows 7 works fine on the mechanical drive but Windows 8 is borked on the SSD, This only points to one logical reason, Your SSD is shafted.
both ssd's shafted!
W8 is shocking.
OK... own up, how many other readers Googled 'PEBCAK'?
I know I had to... but now I know!![]()
I have to say i've had a relatively similar experience, it hated Autocad and would crash randomly when opening drawings, the apps would relentlessly just stop and then never work again. It used to constantly throw up errors the would need repeated runs of;
dism /online /cleanup-image /restorehealth
And
chkdsk /scan / chkdsk /spotfix
It would constantly just black screen on boot and then several ms updates would not install. I was convinced it was hardware but could find nothing, it ran memtest over a weekend (its a work pc in the office). I bit the bullet and begrudgingly bought win7 (I did like 8) and its been faultless since November 2013.
The w8 fanboys will be After you know.
I agree with you. Poor os.
I'm sorry but you can't draw a conclusion about a whole OS from your experiences due to faulty hardware.
We use PICNIC in the office, much easier to remember when abusing customers daft support calls![]()
