I often see cooking heating instructions that say to ensure the food is served piping hot. How hot is piping hot? What specific temperature are we talking here?
The answer isn't on the first page of Google. You fail.
1. Piping Hot -- This expression was used as early as late medieval times, referring to the steam that shot out of a spouted tea kettle, a device in use at least since ancient Mesopotamia. In other words, "piping hot" means "boiling hot." Chaucer used the expression in 1386, as quoted by wiki.answers: "Wafres pipyng hoot out of the gleede" ("Waffles piping hot out of the fire"). On the other hand, when Shakespeare used the word "piping" two centuries later as an adjective, he was referring to bagpiping.
Making sure food is hot enough
To test if food has been properly cooked, check that it is 'piping hot' all the way through. This means that it is hot enough for steam to come out.
Some foods change colour when they are cooked. Looking at colour is especially useful for checking meat.
That doesn't state a specific temperature which is what the question was.
Since sausage rolls do not, as far as I'm aware, have a boiling point, I suggest that's a meaningless question.So how hot does, say, a sausage roll have to be to be considered 'boiling hot' then?
/edit - the temp that steam comes out is subjective to the room's temperature too isn't it?
The boiling point of water is 100*C, thus it is easy to check that a food item is boiling hot!
But a sausage roll isn't water though, is it? Like the boiling point of lead is lower than that of steel then the 'boiling' point of a sausage roll is different to that of water.
I'm well aware of the saying's origins, I just wanted to know if piping hot also refers to a specific temperature, otherwise it's a fairly arbitrary instruction![]()
