£600 build
26 Jul 2012
Hi there. Looking for advice on the best rig I can build for £600. Looking to use it for gaming. Everything will be needed (except monitor,keyboard,mouse) including an OS. Thanks
Heres BF4 CPU scaling.
Then the closest match I can find on the Anandtech CPU bench is this - http://www.anandtech.com/bench/product/699?vs=702
You can use a VGA=DVI adapter that comes included with the cards.
The R9 290/290X are examples of modern cards where a VGA analog monitor will not work as they only pass digital signals through.
Would that build work with the motherboard switched to a
Asus M5A78L-M/USB3 AMD 760G (Socket AM3+) DDR3 MicroATX Motherboard
and the case to
Zalman Z11 Plus Midi Tower Gaming Case - Black?
I wouldn't be changing motherboard, the one you have suggested uses a very old chipset.
Changing case won't be an issue
