[TW]Fox;26024432 said:
The fuss is about how bizarre your request is - you want to lose money in order to stop yourself 'dipping in and out'. Why not treat the problem not the symptoms?
How am I loosing money? last time I checked, I am not loosing anything, I am just not gaining as much interest
IE, instead of £11.50 worth of interest from £500 at 2.3% I would be getting £7.50 per £500 @ 1.5%, hardly something to cry about, but I certainly wouldn't be loosing anything, so not quite sure where your getting that from.
If your willpower really is so poor that if there is a balance in a linked savings account you will immediately drain it then just open an ISA with another lender or something, then it doesn't show up. You can then pretend you don't have it if thats what it takes to stop you randomly buying things.
As I mentioned, my willpower has been improving, but I don't really have the time anymore and want to bang as much as I can away seeing as I am nearing on 30 and have spent the last 10 years of my life trying to save without spending, and not getting as far as I wanted, whats so hard about understanding that? why do you think the next 3-5 years will be any different?, I am not spending left right and centre, but at the same time I look at an ISA as an instant access account, as thats exactly what it is, that you can, and will dig in to at any time, weather it be seeing something you want, having to fix something. As I said I do have an ISA for this reason, but I also want to shift some of that, and start pumping in to, an access account for a house deposit.
The most efficient way for you to save is to put the money into the highest earning savings account and then... not spend it.
No, the most efficient way for me at the moment is to lock the money away, as you will probably find me using it on something which it is not meant for, so no, it wont be the most efficient way.
Not spending it - Some people will find this easier to do than others
