I have recently purchased the components for a new self-built PC and am having cooling problems across the three graphics cards when they are at full use. As such I've decided to change to watercooling but this is not something i've ever done before so I'm looking for some advice from you guys. The relevant components of my system are as follows:
Motherboard: Asus Rampage IV Extreme Black Edition Intel X79 (Socket 2011) DDR3
CPU: Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor
Graphics: Asus GeForce GTX 780Ti DirectCUII OC 3072MB GDDR5 PCI-Express x 3 SLI
PSU: Silverstone Strider Series 1500 Watt
The case I'll be using for the final set-up with watercooling will be this one:
http://www.overclock3d.net/reviews/cases_cooling/lian_li_pc343_atx_case/1
Can you please advise what components I'd need to purchase to watercool this setup (I know roughly, ie radiator, reservoir, pump, fans, tubes, connectors, thermal paste, coolant and 4 x waterblocks for CPU and GPUs but I was looking for specific recommendations if possible, and also if I'd forgotten anything!)
Also, the case above will be large enough to host two separate watercooling circuits with their own pump, reservoir etc - one for the CPU and one for the GPU. Is this a setup you'd recommend or is one circuit sufficient?
TIA!
TIA!
