- 31 Oct 2011
Hi all,
So, I don't post here that often. Having just read over a few other topics, I should, because some stuff on here is really quite useful. Generally I post here because I need help. I'm an IT pro. of 18 years, but sometimes, we all just need some other people's advice / input. The bottom line, is that's what this topic is about. I need some help from anyone that can offer it.
I'll outline my issue.
I have an i7 3770k, which I purchased in November (from Overclockers), and until 3 weeks ago was working fine. Then, I started experiencing blue screens. Many blue screens. In troubleshooting, at first I started with the simple things; re-installing Windows, updating BIOS, drivers, etc. None of which even resolved my issue, in fact, it began to get worse.
The blue screens (of which I have records but will not post as there are so many) vary so much that I was struggling to pinpoint where to start troubleshooting; the blue screens related to both hardware (such as memory management) and software (driver errors etc.).
I also checked the Event viewer and under the System log, there were warnings regarding the processor threads timing out (ID 19). Google wasn't much help for that one as most people said "ignore it!". Having not experienced that problem before.. I did ignore it.
In the process of troubleshooting, I started with the software/driver related blue screens first. I stripped down my machine and rebuilt it without connecting/installing any removable devices (with exception of keyboard, mouse etc) and using a single SSD and blu-ray optical drive. No other hardware connected. I re-installed Windows probably around 15 times - Windows installed fine, no problems - but when it came to installing drivers, or even once Windows was installed (thus during general running), I would start getting blue screens. I created restore points after every driver issue to see if I could pinpoint one in particular causing an issue, but it seemed to be completely random. No joy.
I then moved on to testing hardware. Fortunately I have so many builds that the spares I have are compatible in various set-ups so I could test most hardware. I tested hard drives (both mechanical and SSD), memory, graphics cards, wireless cards, optical drives, water and air coolers. Nothing made a difference, I'd still get blue screens. So I ruled out any hardware issues, with the exception of the possibility that it could be the processor.
So, I attempted to test the 3770k using Prime95. As soon as I clicked the stress test button, Prime95 crashed. On one occasion I had an instant blue screen. I tested multiple times to no avail. I guessed it had to be the processor. I was confident there was no physical damage; no heat damage, and it hadn't been overclocked. So I phoned Overclockers and RMA'd the CPU.
I had an email from Overclockers this morning - they ran a test on the CPU for 30 hours in Prime95 with no errors. So, it's not the processor.
Here's where it gets really confusing. On sending back the RMA, I swapped out the processor with a Celeron G1610. I haven't had one blue screen since installing it. No problems whatsoever.
I explained that fact to Overclockers Tech; but as far as they are concerned the (3770k) processor isn't faulty (which is fine; no complaints there). They explained that they couldn't support the rest of my system (fair enough, even though all my parts for the last 10 years are purchased from Overclockers; a minor issue). I am assuming that Overclockers didn't want to risk giving false information without diagnosing the system as a whole, good on them.
They advised that I take my PC into a local tech. lab to see what they make of the issue. I have no problem with doing that, but before I do.. anyone got any ideas?! I am at my wit's end. All the parts I (should) be using are under 6 months old. It just doesn't make sense. I can't RMA literally every component as it will cost a fortune.
Being an IT pro is clearly no help here, it's not a "standard" problem, so that's why I am begging for some help!
So, here's the full spec. of the system:
i7 3770k (currently using G1610)
ASUS Maximus Extreme V
Coolermaster Seidon 120 (currently using Akasa Voodoo Venom)
Corsair Vengeance 1800mhz (4x 4gb dual channel, matched pairs) but currently using Corsair Vengeance 1600mhz Low Profile (2x 4gb matched pair)
OCZ ZX 1kw PSU
Samsung EVO 500gb
WD Black (1TB x2, 2TB)
akasa internal card reader
LG blu-ray optical drive
Geforce 680 SLi (currently using single Geforce 570HD)
Any help anyone can give would be very much appreciated.
There is one thing I can think of which occurred as I was typing this out: the problem, clearly, lies within the processor infrastructure; but neither processor is faulty, yet one processor works and the other doesn't. The only difference I can think of between the two, is that the G1610 doesn't need to draw power from the 8-pin CPU power socket, yet, I assume the i7 3770k would definitely need to do that. Possibly the next place to look?
Please help.
OCZ ZX 1kw PSU
Samsung EVO 500gb
Please help.
