** AMD RADEON R9 280 AKA HD 7950 ONLY £189.95!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
A 24hr Pre-Order ONLY special as stock arrives tomorrow:-
VTX3D Radeon R9 280 3072MB GDDR5 PCI-Express Graphics Card @ £189.95 inc VAT
The VTX3D R9 280 is the best value for money high-end gaming graphics card you can buy. Essentially this card replaces the famous HD 7950 making it great for the latest games such as Titanfall or mining crypto-currencies.
Specification:-
- Litecoin Hash Rate: 500-700
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 855MHz
- Boost Clock Speed: 960MHz
- Shader Architecture: GCN
- Stream Processors: 1792 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 2yr Warranty
Was [£199.99] Inc. VAT
Only £189.95 inc VAT.
ORDER NOW
Bet i could sell my 7950 for more than that :p
Im waiting a while as this 7950 i have is still.. Awesome!
A 280x at around this price and i might be tempted ;)
I didn't see that coming :p
Kudos to you tho', SOLD!!
*edit*
Was gonna do a test flash but can't find a bios. I don't mind buying the card, then use that bios tho ;)
You need to use a BIOS from the same make of card as you have now.
So if you have a Sapphire 7950 Dual-X, you need a 280 Dual-X BIOS for example. ;)
Another £10 and you'll be at the same price as the 280X VTX3D available elsewhere(with free delivery).
Knock a score off and i might be tempted. ;)
We need mid-range Maxwell to freshen up the market a bit.
Problem with that is if we get another Maxwell on 28nm, all we going to get is another card that's waving low power consumption, but still worse bang for bucks than the other cards at similar current price points much like the 750/750Ti. They need to offer a card with at least around GTX670 level performance at sub £200, or it's pointless regardless how low power consuming it is. But with the GTX760 being at £200+, I can't see that happening.
This.Is.Completely.True
Banging on about power consumption is irrelevant for gamers on lower end cards. It came up on a recent thread when comparing the 270x and the 750ti, the 'savings' in power consumption is not even worth thinking about when talking about the power difference of a single light bulb under load. The appeal for miners is there but what i want to see is gaming cards, not mining cards!
