Nasty bland MPV hatch with a derivative powertrain, off the shelf turbo and awd bolted on to it, all for 45k, then spend the next few years in the garage on a weekly basis getting it fixed. Sounds appealing.
You do know that AMG built the engine right not some random tuner?
The likes of Megane 265, Astra VXR, Focus ST, Golf GTI, Leon Cupra are all around the 25k mark last time I looked.
The Merc claims to be a hot hatch doesn't it? Those are all hot hatches, in what way is the dinky Merc hatch better that it justifies a whopping 45k? Please don't tell me power, because power isn't everything, and having a Merc badge means nowt all.
Go sit in a Mercedes and then a Renault, the difference will be obvious straight away. If you disagree then you're very much in the minority.
I had the misfortune of being a passenger in a newish Renault Megane. I flipped the sun visor down and the vanity mirror fell out into my lap. The door grab handle was also coming apart. Common faults across the range it seems, quality right there![]()
