"Titan Tanto" Intel Core i5 4670K @ 4.2GHz Overclocked Nvidia GeForce Gaming PC @ £803.95 inc VAT
Introducing the "Titan Tanto" Nvidia GeForce Gaming PC based on the very latest cutting edge Intel Haswell architecture. Equipped with an Intel Core i5 4670K overclocked to a impressive 4.2GHz, powerful quad core performance combined with the mighty all new Intel Z87 chipset. You can choose up to a massive 16GB of DDR3 RAM runing at an incredible 2133MHz, delivering blindingly quick multitasking performance. Equipped with a formidable overclock and paired with speedy memory, the "Titan Tanto" has razor sharp performance capable of slicing through the toughest games and demanding applications..
Speed is key. A fast system gets the job done quicker, a fast system games harder. The "Titan Tanto" is equipped a fantastic Nvidia GTX 7 Series graphics card, delivering breathtaking DX11 cinematic graphics. With up to a gigantic 4096MB of VRAM allows for massively graphically intense environments to be loaded smoothy, games such as Crysis 3 and Battlefield 4 take full advantage of this hardware acceleration.
The "Titan Tanto" is contained within the stylish, eye catching NZXT Phantom 530 case finished in a choice of colours. Offering ample space and optimal airflow to keep the "Titan Tanto" running cool and quiet. With dynamic and extrovert styling, you will have a truly unique system, be it at a LAN or at home.
Key Features of this PC
- Quad Core processing & up to 16GB of 2133MHz DDR3 memory
- Midi Tower for easily upgradeability
- Powerful Nvidia GeForce Graphics and Software
- Flexible Specification
System Specification
- Case: NZXT Phantom 530 Gaming Case - Red
- Power Supply: Super Flower 550W PSU
- CPU: Intel Core i7 4770K Quad Core Haswell Processor overclocked to 4.2GHz
- Motherboard: Gigabyte Z87X-D3HP (Socket 1150) DDR3 ATX Motherboard
- Cooler: Prolimatech CPU Cooler
- RAM: up to 16GB (2x4GB) DDR3 2133MHz Dual Channel Kit
- Hard Drive: Primary and Secondary SSD & HDD Options Available
- Graphics Card: Nvidia GeForce GTX Graphics Card
- Sound: High Definition 7.1 Onboard Sound Card
Service Package
- Full 24 Month collect and return warranty (Mainland UK and Ireland Only - Return to Base warranty for customers outside of the UK) - Each specification is assembled from handpicked components for compatibility and stability - Telephone, web note and forum technical support
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
Free games provided in conjunction with any components are only provided with this PC if specifically stated in the description above.
Only £803.95 inc VAT.
ORDER NOW
_____
Asus Radeon R9 290 "Voltage Unlocked" 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification
Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950
- Stream Processors: 2560
- Core Speed: 947MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort - Warranty: 3yr
Features
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £299.99 inc VAT.
ORDER NOW
Service Package
ORDER NOW
_____
Specification
Radeon R9 290
- GPU: Hawaii Pro
Features
ORDER NOW
