**** guess, already tried that, all you get is a blank black background.
@SieB, thanks for the info, cba personally, but great info all the same.![]()
For the best truaudio results should I disable dolby headphone and other surround emulation on my asus xonar dgx?
Try it and see. Shanks says it does not matter, but when i listened to the true audio demo it recommended disabling surround processing.
Yes and ive got an audio recording to prove it.![]()
I didn't you lie haaa I think you getting mixed up with something else I was saying can you re-cap?![]()
I don't know exactly i thought i remember you saying it should work even with sound processing on, ie 7.1 in my g35 headset. Not saying thats not the case, but in the AMD demo they recommend disabling it.
Nope if I remember you was saying TA is for Stereo only? but I said no it will work on everything like shown/talked about at the press event.
I use true 5.1 headset so the TA just works, but if you have 2.0 TA will still do it's thing and give great surround audio, adding another layer of virtual surround in the like of Dolby I would guess would mess up what TrueAudio is trying to give?
I not sure as I dont use Virtual so on the part I could be very wrong.
Furry muff yeah my g35's are 7.1 virtual. Still sound ace in game though imo. Will have to try it on and off and see which i prefer.
Yeah give use feedback mate, try 2.0 with nothing added from your Headset software. and TA enabled and then again with 7.1 enabled.
MPC: So a person could keep their existing discrete X-Fi/Xonar/Recon for the superior DACs/ADC, and switch off their effects to use TrueAudio but then switch them back for games that use OpenAL or don’t support TrueAudio?
AMD: That’s 100 percent correct. We designed AMD TrueAudio in the manner that we did precisely because we know users have great audio hardware with high-quality OPAMPS that they don’t want or need to forfeit. Whatever audio device(s) a user has right now, that hardware is ready to go with AMD TrueAudio.
Enjoying my lurking in the shadows so far and TA has brought extra immersion into the title too.
You need to switch any virtualisation off and just run stereo if your headset isn't proper 5.1.
http://www.maximumpc.com/everything_you_wanted_know_about_amd’s_new_trueaudio_technology_2013
@Calin, played a few hours last night on Mantle(as in game 3D doesn't work on 290, I was using Tridef-you don’t use any AA so you play on lesser IQ) I was pleasantly surprised at how decent the actual game looks with max IQ.
Shankers what sound card and headset you running?
