So I recently purchased a Fractal R4 case and Gigabyte 780ti Windforce, upon installing my components into the new case and putting the card in I heard coil whine on high FPS or high stress situations in game, which I didn't have previously with my 680 reference.
Anyway, I RMA'd the 780ti figuring that was the issue, but after reinstalling my 680 it is still present, the sound seemingly coming from my GPU still. Now, if my 680 had made this sound within my duration of owning it I would know, this is the first time. If I remove my 680/780 and run on-board graphics the sound is still present, albeit much quieter. The PSU has a constant low coil whine no matter the task but when gaming the sound is clearly coming from the GPU.
I don't understand whats altered to cause this issue, but I assume it's the PSU? its a Corsair TX 850w, my 780ti was due to be picked up tomorrow for an RMA, but I'm not sure it's worth it considering surely it cannot be the problem if my 680 is also whining now?
TL;DR
-moved components into new case
-replaced reference 680 with new windforce 780ti
-encountered coil whine coming from GPU so organised a return for 780ti
-took 780ti out, put old 680 back in, now I suddenly have whine on that card also when I didn't prior
I can test both cards in a friends system come monday, but obv the issue with that is I'll have to cancel the RMA.
TL;DR
