Board only supports upto 2000Mhz so would be downclocked.
Plus its black.
The games I'm wanting to play are SimCity 5, Minecraft, and possibly in the future some big AAA games. ... programming at Uni in something related to game development.
Just so you know, these £1000 build are way overpowered for SC5 and Minecraft. You could spend £300-400 for a gaming PC that would be just as good in them. Similarly, any office-spec PC will eat up programming tasks, unless you intend to develop games in very graphically demanding engines.
The CPU does come witha stock heatsink. But its small and noisy. The tiny little fan on it will buzz away.
Bigger fans such as that aftermarket cooler will rotate slower.
There are plenty of build guidescon YouTube to follow.
The stock cooler that comes with the CPU has paste pre-applied.
The aftermarket coolers will have a little syringe or sachet of paste to apply yourself.
Fantastic, sorry forgot to ask what should hopefully be the last question! In that newegg video he had to plug the cases USB 3.0 lead into the ports on the outside of the motherboard. Will I have to do the same or are there internal ones? Here's the video. It's around the 27 minute mark I'm talking about.Well if it comes pre-applied then cool, but that must be very rare on an aftermarket heatsink.
Both the 200R and Ronin have a front and rear 120mm installed fan, that should be enough.
The RAM does have heatspreaders.
CPU+GFX cards will work fine together.
Newegg TV: How To Build a Computer - Part 2 - The…:
Most newer motherboards have onboard USB 3 header which you can connect the front usb 3 ports to - also the case should have the correct connector as-well.
Do you know the spec as we can then confirm.
The speed difference is minimal, 50Mhz is peanuts on the grand scheme of things, its the price, it really is a good deal.
There is a years less warranty.
Just saved you another £3 with this all black board,
YOUR BASKET
1 x VTX3D Radeon R9 280X 3072MB GDDR5 PCI-Express Graphics Card £209.99
1 x Iiyama Prolite E2483HS-B1 24" Widescreen LED Monitor - Black £129.95
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £119.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x Gigabyte 970A-UD3P AMD 970 (Socket AM3+) DDR3 Motherboard £71.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x BeQuiet Pure Power L8 530W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in £59.99
1 x Crucial M500 120GB SATA 6Gb/s Solid State Hard Drive - (CT120M500SSD1) £59.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £53.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £43.99
1 x TT eSports Knucker Plunger Gaming keyboard £39.98
1 x Deepcool GAMMAXX S40 CPU-Cooler - 120mm £19.99
1 x Pioneer 24x Internal DVR-221LBK DVD Rewriter - OEM £17.99
1 x Gigabyte M6900 3200DPI Gaming Mouse £16.99
Total : £1,006.26 (includes shipping : £13.75).
Well basically a 4670K and Z87 board adds £100 to the price.
