Hi there
Got from great deals from the green team on Gigabyte products:-
Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TOC-3GD) @ £509.99 inc VAT
GIGABYTE, the world leader in high-performance gaming hardware and system, is pleased to announce the latest graphics card, GeForce GTX 780 Ti Overclock Edition (GV-N78TOC-3GD). With 25% plus CUDA cores than GTX 780, the most powerful thermal design in the world and exciting new technologies, GV-N78TOC-3GD is going to bring all the gamers an extremely gaming experience to a whole new level. The exclusive WINDFORCE 3X cooling design guarantees you to dissipate 450 watt heat out. Enjoy your game play with a stunningly beautiful and quiet design is no longer a dream. It also supports OC GURU II and GPU Boost 2.0 for maximum clock speeds. GV-N78TOC-3GD features PhysX® and TXAA™ technologies for smooth, sharp graphics, and GeForce ShadowPlay™ to capture all your greatest gaming moments automatically. Whether you play on 4K monitors at extreme settings, GV-N78TOC-3GD can provide the horsepower to drive all your next-gen gaming visual experiences.
GIGABYTE innovatively presents WINDFORCE 3X 2-SLOT cooling system, thinner and cooler! The thermal structure contains three ultra quiet PWM fans, an only 2-slot height heat sink with exclusive "Triangle Cool" Technology, two 8mm and four 6mm cooper heat pipes and a high-performance RAM heatsink.
The innovative thermal design guarantees the heat dissipation capability to over 450watt. The cooling performance is 14% significantly better than stock fan! WINDFORCE 3X 450W cooling system not only provides an effective heat dissipation capacity, but also gained a higher performance with lower GPU temperature through the GPU Boost 2.0 technology.
According to the latest NVIDIA® technology, GPU BOOST 2.0, GV-N78TOC-3GD provides gamers an unlimited overclocking capability. By using GIGABYTE exclusive OC GURU II, gamers can monitor and adjust all important settings such as GPU clock, memory clock, fan speed, voltage, power target, OSD and online support. With the upgrade and easy-to-control user interface, GIGABYTE OC GURU II becomes the best mate while using GV-N78TOC-3GD.
Specification:-
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1020MHz
- Core Boost Clock: 1085MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£529.99] Inc. VAT
Only £509.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 780 WindForce 3x "GHz Edition" 3072MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £409.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Features:-
- OcUK has secured an exclusive, only OcUK will receive stock in November!!
- GHz GTX 780 GPU - Best for Overclocking!
- Boost clock OC to 1071MHz
- Enhanced back-plate for asthetics
- 8-Phase Power Design
- WindForce 3X 450W Cooling System (2-Slot Design)
- Black PCB
Specification:-
- GPU: GeForce GTX 780 GHz
- Core Base Clock: 1019 MHz
- Core Boost Clock: 1071 MHz
- Memory Clock: 6008 MHz
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£429.95] Inc. VAT
Only £409.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 770 WindForce 3x OC 2048MB GDDR5 PCI-Express Graphics Card (GV-N770OC-2GD) @ £249.95 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- NEW WINDFORCE 3X 2 Slot 450W fan sink with "Triangle Cool"
- Core/Mem clock: 1137 MHz (std 1046MHz)
- Boost Clock: 1189 MHz (std 1085MHz)
- 8-Phase power benefits with GPU Boost 2.0
- OC GURU II with GPU Boost 2.0 Technology
Specification:-
- Core Clock: 1137MHz (GK104)
- Core Boost Clock: 1189MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
- Product Review: http://www.eteknix.com/gigabyte-geforce-gtx-770-oc-windforce-2gb-graphics-card-review/17/
Was [£259.99] Inc. VAT
Only £249.95 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 770 WindForce 3x OC 4096MB GDDR5 PCI-Express Graphics Card GV-N770OC-4GD) @ £293.99 inc VAT
On board 4GB of GDDR5 memory, satisfying your multi-screen setup, high definition and extreme gaming experience.
Features:-
Specification:-
- Memory: 4096MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£299.99] Inc. VAT
Only £293.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 760 WindForce 3x OC Rev2 2048MB GDDR5 PCI-Express Graphics Card **Black PCB** @ £189.95 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
Features:
- Ultra Durable VGA Design
- WindForce 3x Cooler - Quieter, Cooler, better fans with Triangle Cool Technology
- GPU Boost 2.0
- Support up to 4 displays at single car and maximum 4k resolutions
- Direct Heat Pipe touch technology (DHT)
Specification:
- Black PCB Edition (Revision 2.0)
- Core Clock: 1085MHz (GK104)
- Core Boost Clock: 1150MHzv
- Memory Clock: 6008MHz (Effective)
- Processing Cores: 1152
- Shader Clock: 2116MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£199.99] Inc. VAT
Only £189.95 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 750Ti WindForce OC 2048MB GDDR5 PCI-Express Graphics Card @ £109.99 inc VAT
GTX 750 and GTX 750 Ti cards give you the gaming horsepower to take on today's most demanding titles in full 1080p HD. They deliver 25% more performance than previous-generation cards and up to twice the power efficiency thanks to the next-generation NVIDIA® Maxwell™ architecture. Plus, they come loaded with GeForce GTX gaming technologies like NVIDIA GameStream™, G-SYNC™, and GeForce Experience™
Specification:-
- Core Clock: 1033MHz (Maxwell)
- Core Boost Clock: 1111MHz
- Memory Clock: 5400MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- Display Connectors: 1x Single-Link DVI, 1x Dual-Link DVI, 2x HDMI
- HDCP Capable
- DirectX 11.2 Support
- OpenGL 4.4 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Extremely Lower power consumption (Maximum consumption 60 watts at stock speed)
- NO external PCI-E Connectors required
- Warranty: 3 Years
Was [£113.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Great deals on the Gigabyte WindForce range!
Specification:-
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
Features:-
- Black PCB
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Features:
- GPU Boost 2.0
Specification:
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
	 Thought I was going to save a few pound
