Hi there
OK its 30Hz!
But it is a start!
Dell P2815Q 28" 4K Widescreen LED Monitor - Midnight Grey @ £539.99 inc VAT
The moment you turn it on, you’ll see the difference. With such incredible clarity on an expansive 28-inch screen, the DellTM 28 Ultra HD Monitor - P2815Q delivers an impeccable performance that defies its mainstream price.
Whether you scrutinize spreadsheets, manage marketing plans, or review videos and photos, the Dell 28 Ultra HD Monitor - P2815Q delivers a reliable performance for every task. Boost your productivity with a wide range of connectivity and viewing options.
With our Premium Panel Guarantee1 and the latest environmental compliance, you’ll enjoy peace-of-mind and minimized downtime.
Features:-
- Affordable Ultra HD (3840 x 2160): Experience four times higher resolution than Full HD for pin sharp details.
- Excellent picture quality: With high dynamic contrast ratio and brightness.
- Expansive display: Plenty of space to see all of your applications across an expansive 28-inch display.
Specification:-
- Diagonally Viewable Size: 28.0" (28-inch wide viewable image size)
- Aspect Ratio: Widescreen (16:9)
- Panel Type, Surface: TN
- Optimal resolution: 3840 x 2160 at 30 Hz
- Contrast Ratio: 1000: 1 (typical)
- Brightness: 300 cd/m2 (typical)
- Response Time: 5 ms (typical)
- Viewing Angle: (160° vertical / 170° horizontal)
- Color Support: 1.073 billion colors
- Pixel Pitch: 0.16 mm
- Connectivity: 1x DisplayPort, 1x Mini DisplayPort, 1x HDMI (MHL), 1x DisplayPort out (MST), 1x USB Upstream, 4x USB 3.0 ports - Downstream (3 at the bottom, 1 up to 1.5A charging port with BC1.2 compliance devices at the back)
- Backlight Technology: LED
- Display Type: Widescreen Flat Panel Display
- Display Screen Coating: Antiglare with hard-coating 3H
- Audio Output: Dell Speaker Bar AC511 (optional)
- Height-adjustable stand, pivot, tilt , swivel and built in cable-management
- Flat Panel Mount Interface: VESA (100 mm)
- USB 3.0 Super-Speed Hub (with 1 USB upstream port and 4 USB downstream ports, including 1 up to 1.5A charging port with BC1.2 compliance devices)
- Dimensions with stand (H x W x D): 17.14" ~ 21.67" (435.3 mm ~ 550.3 mm) x 26.04" (661.3 mm) x 8.03" (204.1 mm)
- Dimensions without stand (H x W x D): 15.03" (381.7 mm) x 26.04" (661.3 mm) x 2.21" (56.2 mm)
- Preset Display Area(H X V): 620.9 mm x 341.3 mm 24.45" x 13.44"
- Weight (panel only - for VESA mount): 5.19 kg (11.42 lbs)
- Weight (with packaging): 11.12 kg (24.47 lbs)
- Warranty: 3yr
Only £539.99 inc VAT.
ORDER NOW
			OK its 30Hz!
But it is a start!
Features:-
Specification:-
- Warranty: 3yr
ORDER NOW
