I want to make it 100% clear that I don't care about server popularity. It would be for us to enjoy and that is it; when we get enough on we could play against each other, or if it turns out it is popular we could team stack. I don't want to get one and worry about numbers, simply just for our enjoyment.
I use 20mm, not sure if its the best. I just enjoy dogfighting in the stealth jet because it's closer to BF3 (afterburner/yaw). I use heatseakers and try and get kills on minibirds/transport choppers.
Basically focus on aircraft so that the attack jet can perform it's role.
No aim bot on the defib I see. 0% accuracy.![]()
20mm by far and away the best vs every target except 25mm vs Infy 6 dmg vs 12 (tip - you still can't kill infy with either).
Also, they updated the Jet HUD's Joshcrub![]()
I suck with the stealth jets. I can never see where the tracers are when I fire, too small compared to the attack jets.
My first attempt with a jet ended up with not even taking off, should have checked the controls to begin with!
The only thing I have trouble with hitting are the little birds, so damn small and agile!
what was the name of the site where i can get a premium key on the cheap from chaps?
