Fixing a treadmill. Need a part
Caporegime
8 Sep 2005
Norrbotten, Sweden.
Hi
Does anyone know Anywhere i can get one of these?
It goes inside the rear roller bar of an un-powered treadmill and houses a bearing and a steal bar runs through the center.
I think its called a Nylon flanged bushing. :p
I've tried google extensively but struggling to find anything as the make of the treadmill seems to be a "generic OEM" rebranded thing bought from the local Sports shop (no longer stocked ive checked)
Like this one on Ebay US
The thing cost nearly 2000SEK (£199) so it would be a shame to dump cos of one silly worn out part. (Might even by a whole new roller bar, they weigh a ton though)
I know its a long shot.
Thanks !
(please move to appropriate forum section if this was wrong)
your treadmill cost £200? not surprised it's fallen apart tbh.
how good are those 3D printer things? can they make something durable? people have made real guns from them, so I imagine you could get one custom made albeit expensive for such a cheap treadmill.
Yeah it was 50% off apparently. End of line sale. Shes had it a few years. I said it might be repairable. :D
If you can draw it, I can make you one out of Nylon on my lathe.
That would be great and worth a try. How much would you want for Material/Post to Sweden...? Last i checked snail mail was about £1.50 small packet.
Its not too complicated a thing ill get measuring.
the measurements are accurate the picture isnt quite to scale
i got an A in CDT at school i knew it would pay dividends :P
i forgot a depth of 10mm on the cross section (so from red to green verticle sunk), before the smaller 2mm depth.
Hallo,
Must have kept missing this thread :o
It does not really make sense, can you do diameters, or better yet, send me the part and I can duplicate it.
Just send me a trust :)
