Catzilla 1.0 Benchmark Scores
Load temps can be anywhere between 38-42c @ 1.4v
The only thing that is possibly different card wise is the PWM which I'm running at 571hz
But in saying that most of my gpu scores are higher, unless in someway it's down to the motherboard as I can't get close since the x79 formula???
No idea mate! My load temps for this would have been around 30-35c @1.212v. Those are some great temps for the voltage though. I'm not sure how much having 2 other dormant cards in the loop effect load temps, but that makes me sad.
Edit: wait, are those card temps or CPU temps? CPU for me will 50-55c load
720p entry
780 Ti Ref 1376/3795
4960 @ 4.77
Nice score and on the board.:)
Having dormant cards in the loop if they are turned off and you are starting a cold PC I think tend to help a little bit as they act as a heat sink for the active card.
Card temps.
Nearly 1400 @ 1.212v, that's KPE territory. That's excellent :D can you prise the core out somehow so I can stick it in a classified body??? ;)
What BIOS did you use Frosty?
Recently added new block to my 780 TI and have skyn3trev.1bios flashed, the second version (skyn3trev.2bios) is for boost which going by OCN posts has created instability for some. That's the only reason I didn't use that and prefer stable clocks.
Card temps.
Blimey awesome temps! Albeit not sure what what difference the volts would make to the temps. Need my 1080 rad :D. The core on my best one is a screamer aye :D
Skyn3t BIOS non boost.
Very weird, vram beyond +300 makes no difference if anything it has a negative impact, i can go to +500.
Also ran at 1400 but was artifacting, so couple of clicks of vcore and ran artifact free but scored lower. Gpu temp was 38c
stock settings on everything other than +100mhz on the cpu, was just playing round seeing what all the fuss was about more than anything...
4930k @ 4000
780 Phantom GLH @ stock what ever that is
Hi Kaaps, just updated Bios and GPU drivers so the only benchmark l had installed was catzilla 1.2 so ran that to see if all was well.
4820K:4.6 SLI 670:1202/3488 > result=31423 and that put me at 69 catzilla 1.2 576p rank overall to my surprise. lol :D
Result=31423
Either way up 69> move over 8pack.lol ;)
If l remember Bart_Hunt is OcUK Forum member nice result as well,
Oldphart.:)
Nickolp1974, this has been bugging me, how come you can achieve a 508kHz PWM when my 780 Ti Classy (modded) maxes out at 400kHz?
I've been trying to get mine stable and from what I understand getting 500kHz should help. My clocks so far are 1355/1860 at those volts. Pushing memory more decrease score in all my benchmarks but I see from other submissions such as yours a high memory has scored well. I am missing something?
Hi kaaps, some more catzille scores with latest Nvidea drivers.
4820K:4.6GHz SLI 670:1202/1744
1 GPU 670 576p result=21384-
1 GPU 670 720p result=16818-
SLI 670 720p result=216574-
Thanks,
Oldphart.
How about the part where you are likely using an older version of the Classy tool? :D
Get the latest one from FTW12345 at kingpincooling.com
