I disagree!No such thing![]()
I have a couple of R9 290s for a 1080p60hz display, and all I get out of it is an excessively high framerate and a lot of heat.
There is definitely such a thing as overkill. And I love it dearly.
Its PEBAC, BF4 DX performance on 14.2 is better than 13.12 / 13.11. they have it at 20% less. Its not just me saying that, other reviews show this.
They probably didn't unistall the previous drivers. idiots.either that or the 290X is 25 / 30% faster than the 780TI on 13.11. So which is it?
DX On 14.1/2
Meh.. trueWhatever the reason it is a pretty rubbish review.
Unfortunately due the fact this is the 290X thread, I have to link it in the OP along with all the other reviews.
Play BF4 a far amount so Mantle can be used (when its stable from reading other threads)...
I wouldnt bother going from a 780 to a 290x personally. Its a step up sure, but a lot of effort for not a huge amount of gain.
Mantle is working wonderfully and very stable for 290 users.
Anyone else have an input ?
EK Introduces ASUS R9 290(X) DirectCU II Water Block
EK Water Blocks, Ljubljana-based premium water cooling gear manufacturer, is proud to introduce the full-cover water cooling solution for the ASUS engineered Direct CU II series AMD Radeon R9 290X graphics card.
EK-FC R9-290X DCII water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and its VRM to remain stable under high overclocks.
Base is made of nickel-plated electrolytic copper - depending on the variant) while the top is made of quality cast acrylic material or POM Acetal (depending on the variant). Screw-in brass standoffs are pre-installed and allow for safe installation procedure. The cooling engine uses refined, 0.6 mm wide microchannel structure to even further improve the heat transfer while not sacrificing the famous low hydraulic restriction design.
Up to four EK-FC R9-290X DCII series water blocks can be interconnected using various methods (EK-FC Terminal, EK-HD Tube & Adapter System or EK-FC Bridge CSQ - depending on the water block variant) which allows for hassle-free piping job. The product is available in a three variants, an aesthetic retention backplate is also available:
