HD6950 Pushed to the edge!
17 Oct 2012
unfortunately Mars
Ok, so for a year now I've had a powercolor HD 6950 2GB installed in my rig, its been an amazing card, quite rare, good specs, strong card, but recently I've been looking over as many results from other people as possible, the general score for tests and results:
highest result I found for the powercolor HD 6950 2GB on 3Dmark 11 was a score of 5730, now I presume the card had been overclocked as the basic score for the card is 4400 on 3Dmark 11, I looked over these results and I thought I could do one better :)
So powered down, opened the case and cleaned everything off, checked for any signs or ware or damage, all ok, so shut the case up, powered on and began the long road to victory :D
I loaded up MSI afterburner and played with some of the settings, not touching the voltage yet, couple of tweaks, little raise on core and memory clock, ran 3Dmark 11, here's the first set of results, ignore the cpu as I was also overclocking at the same time, all different results ;)
So a little bit of an overclock, not to bad, shows the card is working and there's no damage or faults :)
little by little I turned up the clock on the card, still no voltage tweaks:
looking good :D
Ok, so what I believe to have done is almost beaten the highest score I could find, so no gloating yet :)
Now decided to play with the voltage, little tweaks here and there to see what happens as well as increasing the memory and base clock :D :
WOW! zoomed up just because I changed the voltage a little bit :) I'm impressed!
But still not over the moon as I knew I had more to go on the card, so again, little bit more? :
Ok now im happy! over the 6000 mark, very impressed :D as I still cant find another 6950 with the same result.
I was going to stop there but I then remembered that the card had a duel bios!!! so an hours research, looked over what cards work, mine was down as a successful card that could be made into a 6970 :D so off I went! drivers downloaded, little switch by the crossfire connectors flicked on to the number "2" mark, all was successful, shaders unlocked and all ready to go for the Secord stage of overclocking!
again, voltage tweak and raise in core clock and memory clock:
Good good, still rising with good results, but not stopping there, all temps are ok, just reaching 72.C on test :D
Little bit more:
Haha ok so that looked like enough, but nope, I was at maximum on core clock and the memory clock, so really the only other thing I could tweak was the voltage :D
So off I went :D tweaking the voltage for the last time :
DAYM! that's impressive, for the card that is, great score and amazing temperature, 34.C on idle, low fan noise for duel fans, only 75.C on max, I'm really happy with the results, quick look at MSI afterburner to show what settings I had the card on:
There we have it, Powercolor HD 6950 2GB pushed to the edge :D very impressed with the results!
If anyone else has the same card or a 6950, then please post your results as I'm very interested in what other people can get, I'm happy :D
thanks
JK Creations
Hell yeah! thanks guys, done the unlock for MSI afterburner, but as a cost, got the good old screen flicker due to powerplay :( oh well, my plans are to reach the limit for the overclock, get some pics, then relock MSI afterburner so the flickering will stop, it is quite annoying but I can live with it :D
thanks guys
JK Creations
It was.
Not just one, but two unlocked@1GHz in CrossFire, cracking cards, still got one in another rig, and the doomslayers said unlocking would kill the card rofl.
nothing special TBH.
I had VTX 6950 flashed to 6970 working on 1140 mhz for almost 2 years :D
This is the EDGE of burning that card :D Sold it to my mate and its still running with that custom cooler on it :)
looking at the hwbot results linked - how do we enter those lists? Looks to me like I may have the second fastest 5750 score - given there are only 4 entries it's not so tough!
Make an account, submit a score.
Gotta follow the rules mind, so a screen with the score/GPU-Z screen+CPU-Z screen.
Doesn't normally take long for the scores to show online and for you to collect your points (if you have any coming, for a 5750 i doubt it)
yeah it'd be no points, was just curious. I'm happy enough to keep ranking myself vs. others of the same card on 3dmark.com but it isn't particularly good for telling how you're doing (searching for a given card tends to miss heaps of results for no apparent reason).
Also no longer have the 5750 so couldn't submit a score now anyway :)
:D
3DMark is pretty terrible for giving you an idea where you 'rank' and HWBot you need to make sure you've toggled LN2/Phase off otherwise you'll always be off the top 10-50 depending on card :p
I think my best ranking for a card was 7th or something, cannot remember if it was the GTX460 or HD5850 :)
Thats pretty good Jacob :)
I used to have a 6950, they are a nice GPU.
We do have an OcUK HWbot team, but I think there is only one or two of us active on it just now. Used to be quite fun entering the competitions as a team. :D
