correct TV height?
25 May 2011
Installed my new 60" TV on the wall, well my friend did for me. I notice when sat down I have it tilted downwards to reduce the height and my eyes are at the bottom of the screen, is that ok?
Your eyes should be level with the centre of the screen, mine are at about a third up the screen. It's also a 60" and it needed to clear my TV cabinet and centre speaker. Though I could drop it a couple of inches, just not got round to it.
Mine is set to have my eyes in the middle when seated on my sofa, looks low when standing obviously, but I dont care.
I've always worked on the basis that your eyeline should be about 20-25% of the way down the screen (from the top) for a tv or monitor.
Reason for this is that it is easier for the eye to view and tend downwards, looking upwards is a strain, which is why people get eye strain - I read this in an ergonomics paper somewhere, and its the same reason why microsoft have the ribbon bar where they do; look down for majorioty of the work but glance up to bar for buttons when required (infrequent)
Eyes to the centre of the screen as mentioned.
Pains me when I walk by people's houses and see these massive bright tv's 2/3 the way up the wall. Neck pain after watching must be awful.
I mounted my tv quite high on the wall and quite enjoyed it that way. I think I recline and slouch on the sofa so it works quite well. To be honest I'd mount it on the ceiling and lie down to watch! It's currently on a TV stand with eyes about in the centre of the screen and it's also fine. My conclusion: mount it where you like.
I thought just under the top bezel for eye height, looks like I was wrong!
That was always my understanding but I think todays super size TV's have forced a change in thinking as they would be pretty much sat on the floor to make this work!
Terrible backlight bleeding krooton! :p
It's off the wall. :D :p
Nice place, krooton.
Depends, do people use something like this?
Maybe...my 50" is on a TV cabinet which was designed specifically to give the TV the correct height (already knew which TV I was having before I bought it)
Gewgling is required.
