Sounds like the grind is too fine, or you are tamping too hard. I've had that when dialing in a new coffee.the puck had water on top when finished. though it was solid underneath
As for you basket getting stuck, I've also had that, and for me it was the 3-way solenoid not working. It works by directs the flow of water through the grouphead, through the steam wand, or releasing the excess grouphead pressure out through the drain outlet after brewing or back-flushing.
Sorry, I should have said. My machine is a Gaggia Baby Twin, but it is almost identical to the Classic. Mine is also 6 years old, so getting on a bit, and partly the reason the valve on mine was sticking (the other reason is limescale). You said you're getting it returned, but I would recommend you try another. They are decent machines, and yours does sound faulty.was the solenoid fault fixable by you or did you need to send for repair?
just wondering if it was me working with a dud for a month or my technique.
Yes.by dense to you mean too fine?
Not had a proper look at them, but I'd look at the Ascaso or the Graef. The Ascaso has stepless adjustment which is better than the stepped adjustment of the Graef, although the Graef has a slow grinding speed (the description says) which may mean less heat and static during the grind. Looking at the review for the Ascaso, you may need to use a yoghurt pot modCould anyone recommend any of these grinders? Probably not the best range but I've got a stack of JL vouchers to spend.
Is that a hand grinder?
I'm massively into this fine Brazilian at the momentjust out of interest what is everyone's favourite coffee on Hasbean at the minute? Loving the Ethiopian which tastes of blueberries!
I'm massively into this fine Brazilian at the moment.
Not had a proper look at them, but I'd look at the Ascaso or the Graef. The Ascaso has stepless adjustment which is better than the stepped adjustment of the Graef, although the Graef has a slow grinding speed (the description says) which may mean less heat and static during the grind. Looking at the review for the Ascaso, you may need to use a yoghurt pot mod.
Heard good things from other coffee nerds about the Sage Smart Grinder.
Depends what you mainly need it for. There is a shim that is added to the Sage to improve it for espresso, I believe they should all have that now.
Better than the Iberital MC2, but not as good as the Mignon. Easier to adjust than both though.
Thing to remember, that it may be badged Sage by Heston Blumenthal... underneath it's Breville.
I have an Ascaso iMini Steel and it is excellent in every way. Very well made, and the adjustment is fine enough that it helps me to pretty much nail every coffee within a couple of shots. I assume that the i1 is even better though I haven't used it![]()
I have that Graef one. It grinds consistently but can be a pain for retention. I sometimes have to give it a good whack to get my 17 grams out. The fresher the coffee the easier it comes out, though. I don't know if it would be any good for espresso as I only use an Aeropress but the reviews I read were positive. I won't buy another if it packs up.
