First car done properly, enjoy it! I often ponder swapping my ST for one of these...
is that limit heavily enforced or do people just ignore it?
Many thanks for your request for an estimate to replace the cam belt and water pump on your Renault Clio Sport 197. The cost to carry out this job would be £949.95 covering parts and labour. This would include a new auxiliary belt with tensioner and roller, timing belt with tensioner and roller, crankshaft damper pulley and coolant pump. All parts and labour are warranted for one year.
I am able to give you a price on the parts but after discussing the labour involved with our mechanic, he was unable to give me a quote re labour. The parts would cost £191.95 for the cambelt kit and waterpump, and they would take about 2 days to order in, however, my mechanic said on this particular vehicle, when you disconnect the battery or drain the water out to work on the vehicle, you have to then reset everything in order for the car to be able start again afterwards, as the vehicle will disable if the sensors read that the battery has been disconnected or that there was no water, even if the water has been put back in. Because of this he is unable to give a time scale for the work at this stage. Our hourly labour rate is £60.
The book time is 6 hours to change the cambelt as it is quite involved, you really need to find a Renault specialist who has the correct tools as its easy for the timing to go slightly out which effects the power. Our local specialists did it in under 3 hours so the total cost was £350 including an MOT and replacing the gearbox fluid i supplied.
