- 11 Dec 2005
- Cheshire
The highlights of this week's deals are as following:
We have the UK's lowest priced 30" monitor on offer this week. The Hazro HZ30WiE V2.0 30" Monitor for only £587.99 inc VAT.
Enjoy true speed with TeamGroup Vulcan RED memory kits, with speeds of over 2133MHz you can multitask like never before. Yours for only £99.95 inc VAT.
Unlimited mobile gaming? The Aorus X7 Gaming laptop features Nvidia GeForce GTX765M SLI to provide intense DX11 gaming performance. In stock now and available for only £1659.95 inc VAT.
Want more? Our whole selection of deals HERE.
Hazro HZ30WiE V2.0 10-Bit 30" LED Widescreen Professional Monitor - Black @ £587.99 inc VAT
The Hazro HZ30WiE V2 is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. Wherever you need it most, the Hazro HZ30WiE V2 performs with consistency and clarity to optimise your visual experience. The Hazro HZ30WiE V2 recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30WiE V2 collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again. With the Hazro HZ30WiE V2, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail. The Hazro HZ30WiE V2 offers three times the workspace of a standard 19" monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30WiE V2 is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency - and, in the case of businesses, an impact on their bottom line.
Features:-
- Aluminum Casing
- LCD Panel: 30" WQXGA colour LCD S-IPS active matrix
- Type: 16:10 aspect Ultra wide gamut TFT-LCD
- Bit Depth: HZ30Wie: 10bit 1.07billion Colors
- Viewing area: 641.28 mm (H) x 400.8 mm (V)
- Resolution: 2560 [H] x 1600 [V]
- Pixel Pitch: 0.2505mm x 0.2505mm
- Contrast Ratio: 1000 : 1(Typ.)
- Refresh rate: 59 ~ 60 Hz
- Response Time: 6ms [grey-to-grey]
- Color Gamut: Wide Gamut 117% (CIE 1976) NTSC [100% AdobeRGB and sRGB Coverage]
- Brightness: 370 cd /m² (Center 1 Point)
- Viewing Angle: R/L : 89°/ 89°U/D : 89°/ 89° (178°/ 178°)
- Connectivity: 1x DisplayPort, 1x DVI, 1x HDMI & 1x VGA
- Surface Treatment: Hard coating(3H), Anti-glare treatment of the front polariser
- VESA Hole Configuration: VESA 100x100 & 200x100
- Dimensions: Approx: 690(L) x 445(W) x 65mm(D) (excluding stand)
- Weight: Approx 11 kg before packaging and excluding stand [approx]
- Power Consumption: In Operation: <150W
- DPMS / OFF: <2W
- Energy Saving Mode: VESA DPMS [Display Power Management Signaling]
- Power Input/Output: DC Input: AC 100V-240V, 50~60Hz, DC Output: DC 24V / 6.3A [approx]
- Inputs: 24V DC Jack, 1 x Dual Link DVI-D;
- Accessories: 1 x Dual Link DVI-D Cable; 1 x IEC 3 Pin AC Power Cable;
- 1 x DC Power Adapter; Instruction Manual
- 2yr Warranty
- Read the TFT Central Review here of 8-bit version: http://www.tftcentral.co.uk/reviews/hazro_hz30wi.htm
Only £587.99 inc VAT.
ORDER NOW
TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLD316G2133HC11ADC01) @ £99.95 inc VAT
Named after the god of fire in Greek mythology, the Team Vulcan is the combination of high-end craftsmanship and top-notch technology. The short version heat sink of Team Vulcan prevents difficulty in installation due to large and bulky heat dissipation device of motherboard. The arrow-shaped opening design helps increase heat dissipation. In addition, the explosively red color combined with diamond cut pattern not only shows great texture but also the crazy sensation of over-clocking speed.
Made of chips from major manufacturers, Team Vulcan passes series of harsh testing and verification procedures which have proven its stability and durability. Currently, DDR3 2400 CL10, DDR3 2133 CL11, DDR3 1866 CL9/10/11 and DDR3 1600 CL9 are available to cover the mainstream Dual- and Quad-channel specifications that pretty much satisfy the demands of players of all levels.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 11-11-11-31
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 17,100MB/Sec (PC3 17100)
- Heat Sink Aluminum heat-sink
- Working voltage 1.55V-1.65V
- Warranty Lifetime warranty
- Haswell & AMD Richland compatible
Only £99.95 inc VAT.
ORDER NOW
Aorus X7-CF1 17.3" LED TFT, Intel Core i7-4700HQ, 16GB DDR3, 2x128 SSD RAID, 1TB HDD, Dual NVIDIA GTX 765M SLI - Windows 8 @ £1,659.95 inc VAT
"AORUS X7 delivers unlimited gaming experience without the cost of mobility and practicability. AORUS products are crafted and engineered from the ground up to signify the timeless legacy of gaming, in which a spirit of ancient gamers shining above and watching over all gamers despite the time shift.
AORUS X7 features NVIDIA® GeForce® GTX 765M dual graphics and the 4th gen. Intel® Core™ i7 processor delivers immense performance, P7393 in 3DMark 11 Test, in a slate-like chassis. The exclusive Thermal+ Technology achieves class-leading cooling effect and unparalleled reliability and stability. Its understated design yet dynamic outlook marks this state-of-the-art gaming gear an effortlessly thrilling, technically dominant and precisely tuned gadget. AORUS’ exclusive software and top-notch components altogether compose an ultimate gaming platform with incredible portability. Though uncompromised gaming pleasure is aimed as the first priority, X7 still makes a perfect companion for graphic computing and daily use.
Discover X7: a great combination of power and agility."
Features:-
- Extremely powerful Dual NVIDIA GTX765M 4GB GDDR5 Graphics
- Vivid Full HD screen with wide colour gamut display
- AORUS Thermal+*Technology - dissipates heat effectively and provides constant stability!
- Superior Anti-Ghost Backlit Keyboard - Never Miss a Shot!
- Features NVIDIA 3D Vision Surround - Supports up to 3 displays for perfect gaming vision!
- AORUS Exclusive programmable Macro Hub simplifies routine operations
- Super Thin at only 22.9mm and extremely Lightweight at only 2.9Kgs
Specification:-
- Screen Size: 17.3"
- Screen Type: LCD
- Backlight: LED
- Screen Resolution: 1920x1080 Full HD
- Processor: Intel Core i7-4700HQ, 2.4~3.4GHz
- Processor Clock Speed: 2.4GHz ~ 3.4GHz (Overclock)
- Graphics Chipset: 2 x NVIDIA GTX765M SLI GDDR5
- Graphics Memory: 4GB
- Chipset: Mobile Intel® HM87 Express Chipset
- Hard Drive: 1000GB, 5400rpm
- SSD Drive: 2 x 128GB
- Memory Supplied: 2 x 8GB
- Memory Size: 16GB
- Memory Socket: 4 x SO-DIMM
- Max. Memory Support: 32GB
- Operating System: Windows 8.1
- Audio: 2 x Speakers, 2 x Woofers, Microphone, AORUS Acoustic+ Technology
- LAN: Killer LAN Chip E2201
- Wireless LAN: 802.11ac
- Bluetooth Version: v4.0
- Webcam: 1.3 Megapixel
- USB 3.0 Port(s): 3
- USB 2.0 Port(s): 2
- HDMI Port(s): 1
- Mini Display Port(s): 1
- Surround Port(s): 1
- Card Reader: SD
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- Security: Kensington Lock
- Battery: Li Polymer, 73.26Wh
- Dimension: 392 x 263 x 22.9mm
- Weight: 2.9Kgs
- Warranty: 2 Years
- Reference Link: http://www.aorus.com
- Unboxing reviews: https://www.youtube.com/watch?v=s128nds5lKE
Only £1,659.95 inc VAT.
ORDER NOW
Features:-
- Aluminum Casing
- DPMS / OFF: <2W
- 2yr Warranty
ORDER NOW
Features:-
ORDER NOW
Features:-
Specification:-
- Screen Type: LCD
- Backlight: LED
- Memory Size: 16GB
- HDMI Port(s): 1
- Card Reader: SD
- Weight: 2.9Kgs
- Warranty: 2 Years
ORDER NOW
