New case, so new cooler too..
1 Dec 2005
Stoke on Trent
Got a corsair 300R for my birthday the other day. I will be putting the rig in my sig into it.
I want a new cooler. Currently have a Thermalright True 120 black edition but im looking to change to a Corsair closed loop water cooler
Which one is better, the H75, H90 or H80i?
Or I guess I could get some new fans for the True 120 as it does keep my cpu nice and cool. What fans would people recommend?
Keep the TRUE and stick a pair of akasa piranhas or corsair sp PWM fans on it, use a PWM splitter to run both from the cpu header. The TRUE is still a great cooler.
Yep, great for heatsinks like the ultra, use two on a k2 here. Shame you missed ocuk's deal on the piranhas though, fiver a pop and equally as good as the corsairs
Only issue is attaching the fans. Whyen I got the HSF it didn't have the fan brackets so currently the fan im using is cable tied to the heatsink.
Well ML I'm going to answer your question, from the 3 units you have listed I would go for the H80i, I do have a 620 Antec and a 80i, the double fans and larger rad on the 80i certainly help cool, I'm @ 3.4gigs on an old quad core and rarely go much above 40C, so I'm happy with both my closed loop water coolers, I don't like heavy air coolers, called my old fashioned:)
Good luck with whatever you buy.
Box..
I've got an Antec 620 as well, I like it - got too fans on it and it keeps the CPU cool on a modest overclock. I haven't gone for an extreme one at all, so don't know how it would do in that situation.
the H80i does seem to be the best option form the 3 you listed, though if I were you I'd have a look at the Antec 920 (if you can find one still) - more or less the same as the 620, but has a thicker radiator (same size as the H80i I believe). Based on the price of the Antec 950, the 920 may be cheaper than the H80i.
