- 30 Jan 2014
Can anyone help me oc the above cpu or recommend a good beginners step by step guide please
I wouldn't mind some advice on this also I am using a Asus maximus vi formula. Just switched from AMD so everythings changed![]()
You have a lot more options in your bios than my Z87-A does but i posted all my settings for 4.4Ghz in another thread that might be ok for you to work upwards from. See here.
I have the same board as DMF, albeit with an i7 cpu. The formula does indeed have more options. But tbh you don't need to mess with any of them when oc'ing. Input voltage, vcore and the chipset voltages are all ive had to change, ram on xmp.
I am testing my CPU 4.5 is my sweet spot @ 1.25v once I go over I start to need more and more (v) going to 4.6 which is stable at 1.31v
4.4 using 1.2v with LLC to 1.216v
Next I am going to work on my core cache from 38 to 42
Very nice pasty, hero is a nice board too. @DMF, 1.25v for 4.5ghz is pretty ok.
Vcore, going by 8 Pack's reccomendations, your fine at upto 1.3 for 24/7 use. Cache, 1.35-1.4v. Some good info in that sub forum. Id link a few threads but unfortunately im browsing on my phone as my two systems have been dismantled.
