Over to to you, Avenged
Haha, thanks?
I just came across it, so I was just wondering, but it looks like a lot of work for me, the cost will also pile on if i need to buy new fittings.
Ive got the res now, I endded up going with phobya silver nickel 250, silver fittings, I already have white tubing, but seeing as im going to be taking the pc apart i may aswell change the tubing.
all i really need now is the coolant and maybe the tubing
I like those phobya reservoirs, my current tube res has a fitting that i cant unscrew or it'l strip the thread (most likely), so i will probably grab one as a replacement.
Would change the tubing or if it is a bit on the long side, cut the ends and re-use it. You can get away with using the same tubing but for peace of mind and a bit more security, its not a bad idea to change it. Tubing wise, whatever size you go for, Primochill is my first choice for clear tubing and Masterkleer is my second.
Like Petey said, the size of the tubing is personal preference. I am a skinny tubing guy, as all my blocks are really close to each other and there are 5 blocks alone in one of my single GPU loop builds.
Acrylic tubing fascinated me when we started to get more brand choices last year, so i tested all the most popular Acrylic fittings to ease my fears of the tubing being not secure enough or particularly difficult to work with. Acrylic tubing does require its own fittings but now we have a fair choice of easy to use decent fittings of varying price tags.
I tried Primochills, Bitspower and EK HD fittings. Interestingly I found the cheapest ones from EK the easiest to use. These were 2.99 each and use two fat custom O-rings to tightly hold the hard tubing in and keep it water tight. Its design is similar to Bitspower ones in this way, and though may not have the same finish as the Bitspower ones, they do come in far far cheaper and need a fair bit more force to separate tubing from fitting. I found that the hard tubing was more difficult to remove from EK HD fittings than the rubber tubing on some compression's.
Primochill fittings sort of disappointed me. They look nice and came in a variety of colours which have a great finish but are a bit on the bulky side for my tastes. They are not true compression fittings, as they do not actually compress the tubing, instead it compresses an O-ring to the tubing from a screw on part of the fitting. They are a little easier to use, as they dont require a sanded edge of tubing but don't feel as secure and tbh i felt that i got more from the double custom o-ring EK HD fitting, which was also considerably cheaper.
If it is too expensive to make the full shift in fittings, you can do what i have done for some of my builds, buy acrylic hd fittings and tubing just to connect the blocks and components on display. Since acrylic is permanent solution to tubing which doesn't cloud, stain or ever need replacing, i felt that spending a bit of time and money on getting crystal clear, straight, block to block connections a worthwhile investment. My earliest use of acrylic tubing has been in a loop for over half a year and it is completely clear. Will also say that you can get away with a £15 heatgun and a £2 hacksaw and just use an edge of a table to do near perfect bends. You have a surprising amount of leeway with acrylic tubing when using rotary fittings as well, so it doesn't matter much if your tubing is slightly off angle or length (EK fittings seal the coolant several mm's from the end of the tubing, so perfect cuts are not needed either).
