- 14 Dec 2005
- Bath
Why is it so expensive on this car to replace the cambelt?
It's the same on all generations of RenaultSport Clio. Cams need locking, and it's a tight engine bay etc. Slightly less bad on the 172s without aircon.
But as it's so well known, any RenaultSport Clio that needs a cam belt will be miles cheaper to buy. Same with the oil - 172/182/197/200s need new oil every 12K/12months otherwise the VVT dephaser will die, and any used one that's had its servicing skimped will have its value impacted. Lots of people seem to be buying them these days without realising what the maintenance is going to cost.
