easy file transfer
3 Jan 2010
Hailsham
Did a file transfer off a vista laptop, reformatted the drive and installed win 7. No problems till I try and install the files. I see the file transfer saved file and tell it to run and it says file transfer can't open it.
Help
Can do later, not there at the moment.
It's basically won't restore the backup file. Just says if cant, not explanation why
Any ideas, gonna try and put a fresh install of windows 7 on.
I could also try moving the files off the external hd on to the laptop.
Has no one else had this issue?
Re installed Windows and still nothing, now trying moving all the backup files on to the laptop and trying it again.
Has anyone else had problems like this?
Bought the back up files to my house to try on a 64bit windows computer and still not working.
Anyone know a way I can recover this file
I found a program called migrecover that is doing the job. For anyone that needs help with this
Hi have you any idea if this migrecover will work correctly in Windows 10 also will it back up & reinstall Ms Outlook accounts, inc passwords, & emails
