To skim or not to skim
18 Oct 2002
In the process of refurbing a house. Upstairs rooms complete, now on to the downstairs.
Upstairs the walls were in pretty bad shape after stripping the paper, we opted for a full reskim of 3 rooms.
I spent yesterday stripping one of the reception rooms and cleaning the surface as much as possible.
Can I get away with filling sanding these walls?
Would you go for a full re-skim to save the hassle?
Plaster looks like it's lifting to me but I can't tell unless I went around the room Tapping.
Trade way to see where you are is to give the walls a quick coat of cheap trade emulsion. With a light coat of paint over it you can pick out the bits that need sorting & leave what don't, It's the most efficient way to work.
How much would it be to skim a room of that size roughly? I'm in a similar position with the house that I've just bought!
Skim it.
Will work out cheaper in the long run, than patching it, with something like Gypsum Gyproc Easi-Fill around £12 for a 10kg bag.
There are a few blown areas, first just go around the room & remove any loose areas, before skimming, that plaster over fire place looks a later addition, so I would remove it.
Strip & prime/undercoat all the woodwork before you have the skim, save you damaging the new plaster with a scraper, also do any electric work needed beforehand.
Why have double sockets around the room when you can just have three doubles on the chimney breast! Lol
:D
Thankfully there are two in the corner that was not photographed.
In a similar vein when I get this room reskimmed, is there anything I should factor in, hiding TV cables, fitting new sockets first, spotlights first, etc etc?
Cheers
Yes, all of these. Depends on your plans for the room though.
I'd get rid of the artex ceiling too.
Most definately get it skimmed, get it done once and not have to worry about it. I wish i wasnt such a skin flint and had my house done a few years ago.
Unanimous it seems! Had our usual plasterer around yesterday for a full quote. £450 for the two rooms all inc, that includes getting rid of the ceilings.
Will update in a few weeks :cool:
For reference, here is one of the rooms upstairs before/after skim+decorate:
