You are still incorrect.Problem with that is the socialist have done such a good job at convincing everyone that right = evil and left = good. That although i do agree that left is collectivism and right is individualism. AS most people have a false understanding of right/left paradigm calling what i represent right wing is only going to think that i advocate state sanction violence like nazism did. Which is exactly what the socialists wanted to get out of the broken left/right paradigm that they propagate. In fact individualism is the complete opposite of nazism and therefore should not be considered right wing. Neither should capitalism or private property rights be considered right wing because nazism was not about capitalism or private property rights but about big state authoritarianism/socialism.
While I agree that many people misunderstand the differences between left & right.
Nazism again has elements of each.
It's clearly at the top of the authoritarian scale.
Economically, it has strong government ownership in some elements, but no collective ownership (in contrast to marxist theory), it also supports private property.
Socially it's extreme right mixed with nationalism.
In no way other than title were they actually socialists/supports of socialism - if you read up on what socialism actually entails you quickly see how they are incompatible.
It's amusing that you accuse the left of intentionally miss-labelling the right to suit a political goal then do exactly the same the other way around.
The truth is virtually no political party is all one way, but has on average many learn towards each axis (many of which sit near the centre with only a slight lean).
It's also a common misconception to believe that supporting the removal of the state makes you a libertarian by default - but it doesn't .
A person who supports replacing the state as a key power with large business isn't actually a Libertarian - as it simply replaces one somewhat accountable organisation with many unaccountable organisations.
you didn't even understand the post, laughable.
