My 650D watercooled build
19 Jul 2011
Reading
Spec :-
i7 3770k @ 4.5-4.9 depending
16gb Kingston 1333 clocked to 1866 9 10 9 27
780ti ref clocked to 4000 on the mem and 1280 for 24/7 gaming
Asus Sabertooth Z77
XSPC Ex280 rad up top with 2x corsair AF140's
EKWB 120 Rad in rear with Corsair AF120
Phobya Extreme 200 v2 in front with Coolermaster megaflow
XSPC Front bay D5.
Superflower 1200w Platinum.
What do you guys think , any recommendations ?
Looks great! Was the phobya a straight forward fit in the front?
Yeah pretty much, all i did was drill 4 new holes in the fan plate on the rad which dropped it in the case by about 5mm, bolted the fan to the rad and then just screw it back into position in the case, took about 10 min in total. The hardest part was the bleeding, i basically had to turn the case upside down :D
tube from 120 rad to GPU will make me a bit nervous but anyway great looking system ,
Can you share what temps are you getting ?
Haha :) , to be honest it looks far worse than it is , it has plenty of give and leak free (so ffar !)
Nice spec! What temps do you get?
With the case closed i get a maximum of 40 degrees on the Gpu and mid 50's on the cpu , this is after a good few hours gaming, at idle i get 28 degrees on the Gpu and an average of 26 degrees across the cpu cores
