- 11 Mar 2008
Hi,
I'm looking to replace the system fans on my case, with aim being to provider better cooling during gaming and also be very quiet when I'm not.
I've got a nzxt 410 Phantom case, with 2 intake fans on the front and 1 on the side. there are 2 x 140mm fan 'slots' on top for exhaust (though only 1 fan in place just now) and a rear exhaust - which currently has Antec CLC on it with 2 x SP120s in push/pull (which are running PWM from the MB)
The stock fans on the case seemed quite quiet initially, but not sure if I've just got sensitive to the noise or if they are making more noise now that they are older.
Also have a 7990, which seems like it get's quite warm (nothing at a worrying level, but I'd like to do better).
The case has a 3 step fan control switch on it, so I'm looking for fans that will be good when on full, but very quiet when I have them down on low.
Had considered a proper fan controller, but as I had to take the HDD cage out to fit the 7990, it means I have drives in the 5 1/2" slots, so no space for a controller
I've had a look at the fans below, all seem to provide good airflow on full, however I've heard reports that some fans don't quieten down much when at slower speeds. Anyone got any experience on what any of these are like on a low speed?
YOUR BASKET
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack (CO-9050004-WW) £22.00
1 x Be Quiet! Shadow Wings Fan High-Speed - 120mm £12.98
1 x Alpenföhn 120mm Wing Boost Plus PWM Fan - Black & White £12.95
1 x Cooler Master 120mm JetFlo FAN 1600RPM - non-LED £11.99
1 x Scythe Glide Stream 1600RPM Fan - 120mm £9.95
1 x Corsair Air Series AF120 1500RPM LED White Quiet Edition (CO-9050015-WLED) £8.99
1 x Scythe Kaze Jyuni 1600RPM Slipstream 120mm Fan £7.99
1 x Aerocool Shark Black Edition Fan - 120mm £6.98
Additional question for best cooling performance - am I correct in thinking that the total volume of air being pulled out of the case should be a little less than the total volume being pushed in? (ie. keep positive pressure)
Thanks.
YOUR BASKET
Thanks.
