- 2 Aug 2012
- Leeds
I fitted an Arctic Accelero Xtreme to my AMD 7950, and was VERY impressed with the results.
So, when i bought a HIS R9 280x Turbo to crossfire with the 7950, i decided to fit one to that too.... and the core cooling is GREAT! Only the VRMs don't seem to be cooled at all! - they still reach 90 - 110 degrees C!
Whereas the VRMs on my 7950 don't go above 60 degrees.
The VRMs on the R9 280x are quite different to the ones on my 7950 - they are very flat.
Here is a picture of my R9 280x PCB.
Here is a picture of where i have fitted the heatsinks.
Have i made a glaring mistake in fitting the heatsinks?
If i've put them in the wrong place, please could you mark on the picture where i should have fitted them, and reupload it?
Thanks again! You guys have been SO helpful with troubleshooting my problems
